Technical Problem hooking up lower radiator hoses
Discussion in 'The Hokey Ass Message Board' started by MERCURYGUY, Aug 28, 2024.
  1. MERCURYGUY
    MERCURYGUY
    Hi guys I have an issue that I ran into on my 1932 Ford. Is currently has a 1950 Stock v8 engine. It has ford water pumps versus the original mercury 1950 water pumps so the fit up works more closely match the 32 setup. I have a brand new 32 Walker Radiator BUT when I tried to mount the lower radiator hoses they do not line up at all and they are 2-3 inches lower than the pump outlets. I do not see how I will make the connections as the pumps and the main belt are also a clearance issue. Does any one have any suggestions or know of some one that may make an adapter to eliminate this issue Many thanks Tom
  2. Petejoe
    Petejoe
    from Zoar, Ohio
  3. Bandit Billy
    Bandit Billy
  4. lemondana
    lemondana
    from Lincoln NE
    Never seen any of these before. Cool!
    Bandit Billy likes this.
  5. clem
    clem
    I managed to find a hose with a tight S bend in it.
    Managed to cut it just right and squeezed it on.
    Early ‘70’s Australian ford fairlane or something odd like that.
    But I had a stock radiator, so maybe different to a walker one
    With no picture, or accurate measurements, I am only guessing that it is similar situation.
  6. F-head
    F-head
    There’s a guy that offers z bend lower hoses for 32 fords on the hamb cl***ified section quite regularly. Can’t remember his name though
    Then you don’t have to use those gnarly castings and 8 clamps
    Tow Truck Tom likes this.
  7. Hippolyt Hot Rods
    Hippolyt Hot Rods
  8. MERCURYGUY
    MERCURYGUY
    many thanks for the info
  9. 19Fordy
    19Fordy
    3263712-03a7783f45feeea5ff5881f5f946fa88.jpg Could you make hoses to contour and fit using copper tubing soldered together. Chroming is not req'd.
    Pumps are early Ford pickup on an 8BA with a Walker radiator in a 40 Ford. This was done 20 years ago. So far, no leaks with a pressurized system.
  10. Bandit Billy
    Bandit Billy
    I grabbed that shot off our cl***ifieds but they were long sold. I did a search and couldn't find them but I did find these on epay
    osage orange and Tow Truck Tom like this.
