Hot Rods Problem rolling up door glass
Discussion in 'The Hokey Ass Message Board' started by caveman57, Feb 24, 2020.
  1. caveman57
    caveman57
    I'm having a problem with the door gl*** on my '57 Nomad p***enger door. that I hope someone has a suggestion on how to correct it. When I roll the window up {manual window} and it gets about 1/2 way up it seems to "bind" up and becomes very hard to crank up the rest of the way. I've dis***embled the door ,tried adjusting the vertical front and rear gl*** run channels. Replaced the window regulator and adjusted the roller track that attaches to the inside of the door and replaced the "felt" material in the rear gl*** run channel. Nothing seems to correct this problem that started about a year ago. The car only gets driven infrequently and was totally restored some time ago. Any ideas?
    Thanks, Pat
  2. sunbeam
    sunbeam
    Rub a candle on the edge of the gl***
  3. Doublepumper
    Doublepumper
    from OR-WA, USA
    Dunno, but after doing all that and getting the same outcome, I'd wonder if the size/shape of the gl*** is the issue. Might be tight somewhere...?
  4. 31Dodger
    31Dodger
    Have you tried pulling it all of the way up without the regulator attached? Doublepumper could be right. Is it new gl***?
  5. nochop
    nochop
    from norcal
    Remove the fuzzies then roll it up
  6. ken bogren
    ken bogren
    Does the gl***, in any position, rock back to front at all?
    clem likes this.
  7. Was the run channel installed with rivets or screws and one has backed out? With the gl*** down, run a paint paddle in your channel to check for interference.
    Crocodile likes this.
  8. hotrod37
    hotrod37
    from Indiana
    Use silicone spray in the "fuzzy" channel. Lubes it up!
    dan31 likes this.
  9. Mimilan
    Mimilan
    I had a similar problem on my 57 sedan.
    It turned out to be the armrest screws were too long
    vtx1800 likes this.
  10. caveman57
    caveman57
    I'm going to try that. I'm going down to a gl*** shop tomorrow and have them grind just a" smiggin' " off the front edge. Thanks for the help
  11. caveman57
    caveman57
    Thanks for the help but all of the inner trim is removed and it's still tight Going to try grinding just a touch off the front edge
  12. caveman57
    caveman57
    that helped some but not quite enough. Thanks for the help
  13. caveman57
    caveman57
    The rear gl*** channel is held to the door with screws and the bottom is adjustable {in and out} I'll try your paint paddle trick. Thanks
  14. caveman57
    caveman57
    pulling it up w/o the regulator the gl*** is still tight.Yes the gl*** is new. I'm going to try grinding the front edge slightly
  15. caveman57
    caveman57
    No the gl*** is probably a little to big
  16. caveman57
    caveman57
    worth a try. Thanks
