Hi Ive recently bought a bob drake 39 brake/clutch pedal stand to save me some time when converting my 37 ford to juice brakes. I used the template that followed the kit to drill and cut out the frame and got the stand exact where it should be.. The clutch pedal on my old manual stand is bent so it will have good clearance to the k member but the clutch pedal on the bob drake 39 stand is more straight and hits it just behind the cut out of the frame.. Now i suspect that the travel of the clutch pedal not will be enough... Has anyone experienced the same issue or is´nt it a issue at all.... I dont want to find out that to short pedal travel will make the clutch impossible to adjust when the body and engine is mounted.... http://www.jalopyjournal.com/forum/album.php?albumid=32094&pictureid=367016
