problem with my crappy 32 5w body mount
Discussion in 'The Hokey Ass Message Board' started by brady1929, Dec 27, 2012.
  1. brady1929
    brady1929
    So right now I am really frustrated with my 32 ford 5w crappy project. I am trying to mount my 32 5w body to a 32 frame that was built in a jig. So I can ATTEMPT TO DO SOME BODY WORK. Anyway, as you can see in the pic, the most forward body mount that attaches right by the firewall does not line up. The picture shows the body outboard of the hole. And it is that way on both sides. I know it does not look like a lot, but when I push on it, I am kind of pushing up against the firewall too. Is there a trick? Am I missing something? Please help me. Thanks in advance.
  2. 325w
    325w
    My after market TCI frame did the same thing. I think the hole is supposed to be at an angle so the firewall is pulled in board as you tighten the bolt. If it pulled straight down then it would not seal as well. That's my story anyway.
  3. titus
    titus
    Yep, the aftermarket rails dont have the angled cowl bolt, the original frame had a angled notch for it.
  4. timwhit
    timwhit
    You can drive yourself nuts trying to figure it out or realize that there's nothing you can do about the frame setup and maybe not be able to move the foot over enough without tweaking something else so ream the firewall foot that 1/16" and move on.
  5. thequietwon
    thequietwon
    That bolt is supposed to be angled ...orivonal frames had a angled notch in the frame to match. Nothing to worry about...bolt is there to tighten body against firewall seal.
  6. titus
    titus
    I myself would yank the body and fix it, it will just be a pain down the road when everything is painted, fix it now and save the trouble.
  7. Buz
    Buz
    I believe that bolt is used for lining up the door gaps. Pull down on it and the back of the door will come up. It never tightens down to the frame.
  8. ronnieroadster
    ronnieroadster
    Thats not a body mount hole. Buz is correct that hole is used on the lower cowl for lining up the door gap if needed so you only tighten the bolt enough to pull the outer skin down its not to be tightened all the way. If the body work is done correctly you will not need to put a bolt in that hole. On my Choped Deuce five window theres no bolt in that location. The forward body mount hole is located inside at the base of the front door post in the subrail area.
  9. brady1929
    brady1929
    can someone please post a pic of an original setup?
  10. cracker head
    cracker head
    See the "dip" in the top of the frame rail, almost at the end of the wishbone?...
  11. brady1929
    brady1929
  12. teach'm
    teach'm
    from Tucson, AZ
    Hey Brady,
    We used a stud instead of a bolt in the hole that pinches the body and frame, which made it easier than trying to get a bolt started. Hopefully the pictures make more sense than my description!
    -Ryan
  13. titus
    titus
    Well technicall it still is a body mount bolt, it just has some purpose to it.
    The stud is a great idea but it still needs to be at an angle, im sure other bodies could get away with a strait but but they all are a little different.
    When im done adjust the doors i measure the gap and cut a piece of dom tubing and then tighten it against that. kinda solid mounting it but being adjusted correctly
    JEFF
  14. turdytoo
    turdytoo
    If you can get a sbc rocker fulcrum on the inside of the frame and run the bolt through it with the nut on the bottom, the angle won't be a problem.
  15. hot rod pro
    hot rod pro
    from spring tx.
    Cut the frame and angle the nut to match huge cowl side. When I use repo frame rails, that is the first thing I do to them.
    -Danny
  16. big duece
    big duece
    from kansas
    I'll take your 5w crappy project off your hands.
  17. alchemy
    alchemy
    Make sure to put the proper rubber seal between the body and firewall, and the proper welting on the frame, when you are setting up the body. BEFORE you do your bodywork. Otherwise you will really be surprised when nothing lines up correctly after paint and polish.
    The virgin '32 tudor I worked on had a slightly thicker rubber pad under the firewall legs than the woven welt that was under the rest of the body.
  18. big duece
    big duece
    from kansas
    Thats a great point about welting on the frame before bodywork.
  19. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    All good info here!!!
