Hot Rods problem
Discussion in 'The Hokey Ass Message Board' started by long island vic, Dec 5, 2016.
  1. long island vic
    long island vic
    im building a 57 ford pickup with a small block chevy.....I had it in stock....the left header has one tube interfering with the steering box.......anyone out there that's done this swap...I don't want to run block huggers
  2. Hombre
    Hombre
    Are you trying to use the cast iron exhaust manifolds?
  3. falcongeorge
    falcongeorge
    from BC
    One tube?? Cut the tube out, buy a J bend (or a set of swap meet headers with the same primary size) and make a section of tube that clears the steering box.
  4. jerry123
    jerry123
    on the one I put together I used ram horn manifolds
    and they worked perfect
