Problems with gas tank sending unit
Discussion in 'The Hokey Ass Message Board' started by VTA53gmc, Sep 6, 2012.
  1. VTA53gmc
    VTA53gmc
    from Ventura
    So I'm havin issues with my sending unit. I have tried everything and it stills registers to half a tank. I just borrowed an extra sendning unit from a buddy, and same thing! Half tank! Anyone else have issues????
  2. Morgan91
    Morgan91
    from Australia
    Details, what type of car 12v? 6v? Stock tank? Stock sender?
  3. fuel gauges and fuel senders need to be matched in ohms range , so without knowing what you have there is no way anyone can help you
  4. OldBlueOval
    OldBlueOval
    from Upstate NY
    I got the same problem with mine and it's a matched set. Took the sender out of the tank try adjusting it but still the same 1/2 tank reading.. But I added a new ground wire from the sender to the frame and got a 3/4+ reading I would try adding a ground wire. Joe
  5. rustednutz
    rustednutz
    from tulsa, ok
    Is this a new sender? Get a digital volt-ohm meter - pull the sender and check the ohm readings as you move the float through it's entire range. You may have a dead spot in the windings of the sender.
  6. squirrel
    If you are using a GM gage from the mid 60s or later, with an original 50s sender, it will do that.
    We're all just guessing though....you need to provide a lot more info if you want a useful answer
