Projects Progress on my coupe - building a rotisserie.
Discussion in 'The Hokey Ass Message Board' started by Kevin Lee, Dec 3, 2008.
  1. SinisterCustom
    SinisterCustom
    Like a VW.......:p:D
    Isn't Bleed's roadster welded to the frame as well?
  2. Roothawg
    Roothawg
  3. Kevin Lee
    Kevin Lee
    Super Moderator
    I don't have an adjustment there. I would have to cut and weld. I got fairly close eyeballing it but it still is a little bottom heavy right now. (I doubt filling the top and finishing the back window will even it out though.) I can spin it to 90 deg and then it gets a little heavy. I was really scared of going too far the other direction and having it flip when I kicked the supports out.
    Maybe I'll add a bar between the top of the B pillars where I can stack weights to even it out? :)
  4. James D
    James D
    Or a really long shifter with a lead shift knob?:D
  5. Abomination
    Abomination
    Dude - there's a caster OUTLET store behind the gas station across Chouteau from Harrah's, right off 210!
    FYI. ;)
    ~Jason
  6. Malcolm
    Malcolm
    from Nebraska
    Very cool - thanks for the update!
    Did you make your front crossmember out of tubing? I've been thinking about doing something very similar, or just buying the 'flattened' A crossmember from Riley Automotive.....
    Malcolm
  7. Django
    Django
    from Chicago
    That's pretty trick Kevin. Nice.
  8. Zig Zag Wanderer
    Zig Zag Wanderer
    '36-'48 Lincoln Zephyrs had unit-body construction very similar to this...simply welded to the frame
  9. hiboy32
    hiboy32
    from Omaha, NE
    that is really looking tough. I really want to see it in person.
  10. Kevin Lee
    Kevin Lee
    Super Moderator
    Just got finished cutting the tack welds and moving the quarters up. Totally evened out the beltline. It's all clamped in place and the doors are fitted too.
    Starting tomorrow I'm going to try to weld a foot (minimum) of sheet metal each evening until it's done. I'm going to have a lot of grinding to do too.
  11. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    hey... dude this looks so rad.
    I love the rotissary...
    thats one hell of a pig... can't wait to see it with the apple back in its mouth...
    complete with blower...
    I agree this has to be one of my favorite builds to watch.
    Tuck
  12. Kevin Lee
    Kevin Lee
    Super Moderator
    Thanks. I have started welding all of the pie cuts on the doors too. Wow.
    Malcom - Yeah, that's just a piece of square tubing with one side cut off and a hole drilled in the middle to locate the spring.
    Feeling like this has some momentum again. Pretty cool.
  13. SUHRsc
    SUHRsc
    proportions are off as are the angles....
    but oh well.... wasting time on friday
  14. Django
    Django
    from Chicago
    ****! That would rule!
  15. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    wow suhr... that front clip looks right at home.
  16. Man that looks awesome!
  17. raven
    raven
    Ha,
    Hey now that Suhr has it all 'conceptualized' you have even more metal work to do...
    Looks good.
    r
  18. HEBE GB
    HEBE GB
    Are you going to run a Chrisman style pointed nose,or a Curtis track style?
  19. SAVAGE
    SAVAGE
    Alliance Vendor
    Sweeeeeet you rock man
  20. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I always wondered on a rotisserie like that how you'd balance the car vertically, so when it rotates it stays balanced?
    I know you touched on it a few posts back, but is there a close guideline?
  21. SinisterCustom
    SinisterCustom
    Zach.....you need to make more of those....that's rad!
    Can ya add a bead along the hood to match the cowl bead?
  22. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Holy ****! That is awesome, that would be an ideal coupe for myself.
  23. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    hes running a 40 ford nose...
  24. SUHRsc
    SUHRsc
    geez.....maybe i should slice up my coupe and make a nose for it! :)
  25. Kevin Lee
    Kevin Lee
    Super Moderator
    Yup, Chrisman, Reath & Malliards, and others of that era.
    Front end is going to be made from two '40 Deluxe hoods.
    As far as finding the center of balance I just took an educated guess. I was a bit off as I said before, but should be an easy work around.
  26. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    that is a RAD pic...
  27. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I think that you should make a nose for my coupe instead.:D
    What Nose did you start with on your track roadster Zach?
  28. Bruce Lancaster
    Bruce Lancaster
    I just xeroxed an old HRM article on building a pointy nose from 2
    '40 hoods...March '55. It might be the 101 car above, but it is not finished in the article.
    Will send.
  29. NoSurf
    NoSurf
    WOW Tuck. that thing is smokin'.
  30. retro54
    retro54
    from PA
    I agree with you all... even though it's photo -shoped, the way that kevin's coupe looks with a nose on it is dead on... never thought a nosed coupe could potentially look so good! can't wait to see what you come up with Kevin!
