Progress on my HA/GR
Discussion in 'HA/GR' started by 348chevy, Jan 26, 2008.
  1. 348chevy
    348chevy
    Here is a picture of my motorplate and flywheel. The motorplate will adapt a Chev explosion proof bellhousing to the GMC engine. This will make me feel a lot safer at 6000 rpm.:D
  2. mudflap261
    mudflap261
    from tulsa
    Iam glad to see yougo with clutch can .Haveing had a flywheel explosion Ican tell you its one experince you dont want to have keep up the good work
  3. Ron Golden
    Ron Golden
    Roy,
    Those look great.
    Ron
  4. Mr. Mac
    Mr. Mac
    Nice work on the motor plate.
  5. buffaloracer
    buffaloracer
    from kansas
    Looks very good. Did you do the plate? Would you mind to tell me how thick is it?
    Thanks.
    Pete
  6. 348chevy
    348chevy
    No I didn't make the plate. It is 1/4 inch thick aluminum. Gary Sellin made the plate for me, he has a CNC mill so it can be made for anyone else. I have a 153 tooth flywheel so if you wanted to run a 167 tooth flywheel the starter location would have to be moved. Gary said that would be no problem. Does anyone know if the GMC bellhousing and the Chev 6 bellhousing are interchangable? If they are then this setup could be used for Chevrolet sixes also. I am going to go tomorrow [monday] and put the bellhousing and transmission on the dummy engine and take some pictures and post them.:)Roy
  7. Rand Man
    Rand Man
    Roy, That looks to be a well engineered part. You're well on your way. More pitures please.
  8. nexxussian
    nexxussian
    I have been told the Stovebolt belhousing is the same on the block, but that the flywheel is different. I don't know if it's just different at the crank or if the starter ring is different too. Haven't tried it myself soI don't know for sure.
    Where did you get the six bolt alloy flywheel?
  9. 348chevy
    348chevy
    Gary made the flywheel also. I went to Auto Zone and bought a 153 tooth starter gear and he made the flywheel. :DRoy
  10. nexxussian
    nexxussian
    Looks slick, is that a used clutch floater for a friction surface?
  11. buffaloracer
    buffaloracer
    from kansas
    Both look outstanding. I guess that is what I like best about HA/GR. Lots of parts made at home and nothing from Summit or Jeg's.
    Pete
  12. 348chevy
    348chevy
    Yes it is a used clutch floater plate for a friction surface. Gary is doing the machine work and I do work for him, like sweep the floor and clean out the lathe. I help him take apart stuff. I buy material to make my stuff so if I can get it for nothing then that is good. Would you believe I'm making my intake from aluminum fence posts, honest.:D Roy I have tried to put more pictures but the pop-up blocker keeps me from doing it.:mad:
  13. 348chevy
    348chevy
    I'll try this again!
  14. mudflap261
    mudflap261
    from tulsa
    thats the way it should be other teams take note .keep up the good work .how long to noise
  15. 348chevy
    348chevy
    Hope to fire it up in 30 to 60 days. Need pistons and they are kinda hard to come by. Ron up in KC is helping on that end. He is like me working for machine work. As we get older you may see us on the side of the road with a sign.:pRoy
  16. Ron Golden
    Ron Golden
    Roy,
    I already have my corner picked out, just have to make my sign.
    Ron
  17. nexxussian
    nexxussian
    “Will Work For Speed Parts”
    Sounds like me.:D
  18. 64 DODGE 440
    64 DODGE 440
    from so cal
    Hell, make a bunch of those signs, we all can use them.
