Projects Progress on Rocky's 34 coupe..last update 9/30/2020
Discussion in 'The Hokey Ass Message Board' started by Rocky, Jan 12, 2009.
  1. dragsled
    dragsled
    from Panama IA
    Good to see you today Rocky AKA Wayne:D, Glad the brake worked out out ok for you,, Tim Jones
  2. Rocky
    Rocky
    Classified Editor
    Thanks again, Tim. Through it all, I forgot the most important [and toughest to bend up] piece of 18 gauge. Has about 6 different bends in both directions. As much touble as we had with that one "channel" piece, I think I'll just have Hemphill bend it for me. I'm inching closer and closer to getting this car on the street!..
    Great photo of your dad, Bob...looks like a 33 chevy to me.
  3. dragsled
    dragsled
    from Panama IA
    We still have the 12 foot brake if you want to give it a try, But hemphill has done some pretty tough stuff for the welders lately,, Remember the hot tank is running again:D Tim Jones
  4. Rocky
    Rocky
    Classified Editor
    I took that 18 gauge I bent up on the brake at work [where I usta work] and Jimmy and I made it into cool stuff. He took one piece and used the plasma cutter [Yeah, I know..not traditional but it's "traditional STYLED!"] to cut out a pair of ovals. Then he used several different dollies and hammers to bend the edges of the holes back to make a nice panel for below the decklid inside the trunk. This piece will have the trunk latch receiver attached to it. The oval holes are so I can get my hands inside the panel to access the attaching bolts/nuts and makes a great place to store car-cleaning stuff and maybe a tool bag. We still need to install nut-serts and drill bolt holes.
    The other panel we trimmed up to fit over the car's gas tank. The panel also serves as a rear firewall [as soon as we make up the filler pieces for the edges adn corners and install a rubber seal around the edges] and it's my package tray.
    The 3 beads serve to strengthen/stiffen the panel so it doesn't drone or oilcan back and forth. We still need to drill our mount holes and install a strengthening rib below the tank under the floor..
    Good **** happening, man!
  5. Bader 2
    Bader 2
    Except if it's 3 or 4 34 coupes hey Steve?hehehe.
  6. That rear panel looks great. You better help Jimmy on the Binder when this one is done!
  7. Roadsir
    Roadsir
    Agreed.... this is coming together nicely. Looks like you may p*** me up!
  8. Verbal Kint
    Verbal Kint
    from Washington
    Nice work, I hope the floors in my 52 hardtop turn out half as clean.
  9. Rocky
    Rocky
    Classified Editor
    Thanks, everybody..
    We had a warmish Christmas day so I modified my Pontiac engine's valley pan and Offy intake to work together. Bolted it up, set the valves, installed the ignition and carb and lit it off. That old Pontiac motor sounds great! Has good oil pressure, a lumpy idle and a mean exhaust note. This was the culmination of about 3 years spare-time work. It'll go in the 34 with a 5 speed behind it.
  10. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Rock box- you need to figure out how to take videos and post them of events like this :) :) Congrats man- I can't wait to hear it-
  11. HOTFR8
    HOTFR8
    Wayne what 5 speed will you use ? Sorry If I missed that.
  12. Tim
    Tim
    from KCMO
    Dude your dangerously close to having a for real car. Super stoked on this :)
  13. 383deuce
    383deuce
    Rocky,
    Been some time since I cheked in on you and boy I am impressed....You are making some great headway. It's looking great. Can't wait to see it running around Nebraska.
  14. jangleguy
    jangleguy
    Rocky: Your coupe is makin' me cry. I'm cryin' all over myself. Can't stop cryin'. Cryin' my eye off. Hurry up - I want to bring my roadster over to Jimmy's.
    Scotty
  15. Rocky
    Rocky
    Classified Editor
    Simon....I'll be using either my Chevy S-10 5 speed or one of 3 Camaro T-5s I have. If I blow all of 'em up, I have an old Saginaw 4 speed with a Hurst shifter.
    Scotty.....quitcher cryin and get that Roadster built.
  16. HOTFR8
    HOTFR8
    Ah, OK. You may recall I have a 5 speed in the T. Will make for a fun car to drive.
    As for you Scotty I have no Brothers :rolleyes: You two guys crack me up some times.
  17. Rocky
    Rocky
    Classified Editor
    we got the trunk latch panel done, mounting holes drilled, nutserts installed and bolted the panel in place...it fits! We also drilled the holes and installed nutserts for the fuel tank and mounted it tonight.After reaming the mounting holes, it also fits.
    Next, we'll install the trunk latch [original] and fab up a latch "loop" for it to capture. I have an original loop but it's really twisted and bent, torn, stretched etc...
  18. Rocky
    Rocky
    Classified Editor
    Trent...this small stuff seems to take forever but it all has to be done.
  19. Yup things many folk gloss over.
  20. Tim
    Tim
    from KCMO
    Keep on truckin!
  21. HOTRODPRIMER
    HOTRODPRIMER
    Every time I check in it's getting closer,,looks great.
    Hopefully the weather will improve and your hands won't freeze!:rolleyes: HRP
  22. And done well! Nice work!
  23. Rocky
    Rocky
    Classified Editor
    Tonight we worked on the rear firewall/gastank cover. Did totally boring stuff like drill and tap mounting holes for the cover. Had to partially dis***emble the back window ***embly to get room to drill/tap for 10/24 stainless screws. Yeah, I know.......yawn!
  24. Tim
    Tim
    from KCMO
    It'd probably go faster if you didn't have to hand build every piece of the car haha.
    Looking good man, your getting painfully close. I know you'll have a running ch***is for that thing ready to rock faster then it took you to drill and tap all those holes.
    So damn close!
  25. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Go rock go :)
  26. Angry Frenchman
    Angry Frenchman
  27. Rocky
    Rocky
    Classified Editor
    Jared...did you get your parts today?
  28. Angry Frenchman
    Angry Frenchman
    I got the driver side fitted all ready. Just got a little left of the p***enger side. wait till you see the pics of what was removed. thank you Rocky!
  29. hotrodderhaag
    hotrodderhaag
    Looks like your hard work is paying off. Nice car. How's the Steve's quarters fit? Herd they were best of the best! Can't wait to see it done. Subscribed
