Project: 29 model a (i dont have a name yet) started
Discussion in 'The Hokey Ass Message Board' started by chevy12, Apr 25, 2011.
  1. What shocks are you using? Extended and compressed lengths? Part number? I'm trying to get the right size for my '29 AA, and the shocks I have are too short.
    Great project, by the way. So impressed with the frame work and the subflooring.
    X2 on the chopping vs. your height. I'm 6'2" and that AA cab puts my kneecaps in my nostrils, even w/o a chop.
    davo461 likes this.
  2. chevy12
    chevy12
    ha im not sure because this way the sticker is right side up on the shock but on the website they are the other way around...
  3. chevy12
    chevy12
    The shocks are from QA1 they are the streeters. They have about 6 different lengths to choose from depending on how your setup is and if you want a firmer or softer shock.
    I have a plywood seat with foam in there now to test and set up my steering column and i have a foot above my head with no chop.
  4. Awsome man..i got a 29 5window that I can't wait to start building
  5. chataf
    chataf
    Are you going to lay down some sheet metal on your floor soon?
  6. chevy12
    chevy12
    ok finally some more updates been slacking on those lately. got the steering almost done and pedals pretty much done. both gave me lots of troubles it will be a big check seeing these done.
  7. chevy12
    chevy12
    here i had to machine the drums so the steering arm would clear the axle.
    and my modified steering arm.
    here is my pedal setup and my masters installed
  8. chevy12
    chevy12
    here is my steering arm coming off the steering box that i made.
    and my mock up for my pitman arm to make sure everything works before i have the real one lasered out for me.
  9. sharpmark
    sharpmark
    damn - theres some interesting builds on here ! you have some great ideas and thanks for the pictures.
  10. chevy12
    chevy12
    shocks mounted, i know not traditional but you cant see them so i went with ride quality instead.
  11. chevy12
    chevy12
    ****** crossmember and mount finished
    ready to start the chop
  12. critchdizzle
    critchdizzle
    from Owasso, OK
    How do you have the subframe attached to the frame?
  13. chevy12
    chevy12
    sub frame? you mean the floor of the car? one page 2 you can see the 8 bolts that hold it to the frame. welded in some threaded bungs to the fame.
  14. critchdizzle
    critchdizzle
    from Owasso, OK
    Yeah, that's what I meant. I thought that's what it looked like, just thought I'd ask.
  15. tierod
    tierod
    Kool, It looks like it had a Honeycomb radiator, be carefull of that, there hard to come by...
  16. clem
    clem
    what difference does it make?
  17. scrap metal 48
    scrap metal 48
    The difference^^^ is there are 2 chambers to modern shocks and the inner chamber should have oil in them at all times.. If mounted upside down the oil can run out of the inner chamber and hurt the damping effect...
  18. chevy12
    chevy12
    flush mounted gas cap done
    and fill tube welded in
    bracing in and ready for the fun. Chop time!
  19. chevy12
    chevy12
    OFF with the top!
    4" chop
  20. chevy12
    chevy12
    so I did the back a little differently. took the middle section out.
    then welded the sides in. no need for re leaf cuts when the pressure is off.
    then pie cut next to the window to line up the seam again.
    back in place
    with no big cuts up the side
    body is done. now doors, windshield, and all the other little pieces.
  21. Oldbill51
    Oldbill51
    Really liking your build, neat job on the chop.
  22. chevy12
    chevy12
    Forgot to take some pictures for awhile. right now i have to body off the frame to finish some welding underneath then ill go back and photo what i have done.
    frame
    54reno likes this.
  23. chevy12
    chevy12
    ok got some more pics of things ive got done
    finished the quarters
    cleaned up the axle opening
  24. chevy12
    chevy12
    made some inner panels to strengthen the quarters
  25. chevy12
    chevy12
    body back on and seats done
  26. chevy12
    chevy12
    tail lights done
    axle cut outs
  27. chevy12
    chevy12
    steering brace
    brace hoop hidden behind
    visor on
    and now off to sand blasting
  28. wheeldog57
    wheeldog57
    Very well done. Lots of cool tricks on your build, thanx for posting
  29. Preacher
    Preacher
    nice build thread and cool style... looking great.
  30. chevy12
    chevy12
    carbs before
    after
    setup
