Projects Project 29 Phaeton
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jan 29, 2013.
  1. 340HilbornDuster
    340HilbornDuster
    I think I'll go with PPG DP40LF Epoxy Primer.
    Pro's n' Con's?
    With A coat of (Right now I'm leaning towards) Dark Green on top.....Color could change by tomorrow...?
  2. Bruce A Lyke
    Bruce A Lyke
    The Blue on my wagon is DP (90??) epoxy primer
  3. 340HilbornDuster
    340HilbornDuster
    Baking in the sun to get all moisture out!
    Sometimes is the small things in life that make U Happy! (Sweden's most purchased Car!)
    Pilot Holes Done Ready for 1 inch hole saw...
  4. 340HilbornDuster
    340HilbornDuster
    Two Weeks ago I said "time for some paint"
    ...Every time I do something I remember something else that I forgot....
    Needed to finish up the front frame horns...to keep water out...finish it up!
    (Since i welded up all the holes in the bottom of the rails...)
    Made a new spreader bar
    Schedule 80 pipe I had laying around fit around it nicely to seal up the front!
    The left Horn moved a bit from welding so it got adjusted with the rose bud!
    "Suport frame" ends capped.
    5 holes down - 16 to go!
    Time for some Paint......
  5. 340HilbornDuster
    340HilbornDuster
    OK - No Paint yet....
    Boxing front /spreader bar done.
    Roll Hoop Brackets
    Brackets Welded to frame (not subframe!) - Hoop welded to plates and bolted to brackets.
    (otherwise I won't be able to remove the body in the future)
    + Need some of these...
    Measure X3! - Should have tacked all of this on before I removed the body...Live & Learn.
    Dannerr and AndersF like this.
  6. 340HilbornDuster
    340HilbornDuster
    1463288760726.jpg 1463288811522.jpg Done..
  7. 340HilbornDuster
    340HilbornDuster
    Next time i'll by one with pukas in it allready! 21 pukas for good luck!
    (300RPM on my drill press is still to fast!)
    Good "ol 30W worked better than that cutting fluid (too Sticky!)
  8. 340HilbornDuster
    340HilbornDuster
    Get the brake drum off - A small job...
    Started with this - don't own a big puller
    Ended up with this - a Rosebud and a sledge hammer for a few hours..FUN! 20160520_184854 (Small).jpg
    AndersF likes this.
  9. 340HilbornDuster
    340HilbornDuster
    Maybe this had something to do with it........................................DUH!
    This article only applies to early Mopar (pre-1965) 8.75" differentials with tapered axles.
    The prevailing opinion when anyone asks on just about any Mopar specific forum, is that if you have a 1964 or earlier Mopar, the first thing you should do is swap out the tapered axlerear end for a 1965 or later unit. Why this is the prevailing opinion is easy to understand when you consider that doing a brake job on one of these axles can be a real pain in the ****. It requires a special puller to remove the drum/hub ***embly, and then you have to have a machine shop separate the hub from the drum if it needs to be replaced. The hub and drum are held together because the lug bolts are swedged (a procedure that is similar to riveting), which locks the two pieces together into one unit. This was a common practice back in the day and was used by Ford for decades. It's unclear why Mopar kept using this system well into the 1960s, but it's just something Mopar enthusiasts have to deal with.
    http://www.crankshaftcoalition.com/wiki/Mopar_Tapered_Axle_Rear_Brake_Conversion
    I didn't need no stinkin' "special puller" (OK, I kinda made one) or no stinkin' machine shop!
    Never give up!
    I'm getting rid of those Swedged Reverse Thread lug bolts anywho!
    (ou can see the Swedge in the second picture)
  10. 340HilbornDuster
    340HilbornDuster
    Cleaning up the surface rust...almost ready for paint...then this happens out of the blue.
    The sun cam back out again and dried it out.
    So I painted in the breaks and rolled it inside between (2 coats of DP74)
    Rear View
    Bad to the Bonez
    DANG ... almost paint...!
  11. AndersF
    AndersF
    I have 3 Dodges with those brakedrums and yes, they can be stubborn.
  12. 340HilbornDuster
    340HilbornDuster
    BTW...i didn't go with green.Final color will be Cherokee Red.
  13. 340HilbornDuster
    340HilbornDuster
    I was thinking of bondoing the welding scars...I'll leave 'em... gives it character!
    The "holy axle" is cleaned...chamfer the holes B4 primer tomorrow!
    kiwijeff, AndersF and kidcampbell71 like this.
  14. 340HilbornDuster
    340HilbornDuster
  15. 340HilbornDuster
    340HilbornDuster
    Frame Flippin Time. (hardly enough room to flip it)
    Wifey helped me out...She's tuff!! No frame Painting today though...Thunder and Lightning!
    finished primer parts in side garage
    Never really liked the look of those "****ons"...so I swapped the main leaf and cut some of the others...
    Much Better... and lotso adjustment if needed!
    kidcampbell71 and AndersF like this.
  16. metal man
    metal man
    Looking good Tommy.
  17. 340HilbornDuster
    340HilbornDuster
    Mahalo Jim!......I'm finally starting to see a light in my tunnel!
  18. 340HilbornDuster
    340HilbornDuster
    [​IMG][​IMG]
    Front spring
    Hope it doesn't rain tomorrow! !
    Sent from my SM-G900V using H.A.M.B. mobile app
    OahuEli, kidcampbell71 and AndersF like this.
  19. 340HilbornDuster
    340HilbornDuster
  20. 340HilbornDuster
    340HilbornDuster
    [​IMG][​IMG][​IMG]
    Have to get it in b4 the rain...big black clouds, but no rain...never know...when it does come it's usually buckets...
  21. qzjrd5
    qzjrd5
    from Troy, MI
    Looks great! Keep it up!
  22. 340HilbornDuster
    340HilbornDuster
    Spring has sprung
    That PPG - DCC Urethane stuff is strong!!!
    I dropped a couple of leafs... not a scratch
    I especially like those built in spring clamps.
  23. 340HilbornDuster
    340HilbornDuster
    A piece of tape and a fee drops of black DCC...later....
    BradinNC, kiwijeff, AndersF and 2 others like this.
  24. 340HilbornDuster
    340HilbornDuster
    Brakes are kinda "billety"....(don't tell anyone)...rounded off the cornes and i'l paint'em black..
    Paid 100bucks at the swap met with caliper and all...
    Paint stripper...
    It's like a model car.
  25. 26hotrod
    26hotrod
    from landis n c
    So glad I found this thread! I took time to read the whole thing and really enjoyed it. Your photos are great and the post are awsom. I have a 26 T coupe ive had for 18yrs I wouldn't take anything for. It sets on a 32 frame with a SuperBell axle and 4 bar front and back. I hope you enjoy your hot rod as much as I enjoy mine..............(coupe is in RodAction mag July '85 issue pg26)
    kidcampbell71 likes this.
  26. 340HilbornDuster
    340HilbornDuster
  27. 340HilbornDuster
    340HilbornDuster
    That's not gonna work....
    It's my fault. ... I must have a pre 1962 axle.
    Got 2 new 8133-S seals of E bay...
  28. 340HilbornDuster
    340HilbornDuster
    Seals fit in center of backing plates....[​IMG]
    It uses shims in liu of adjusters...
    News to an old mopar guy....me!
  29. 340HilbornDuster
    340HilbornDuster
    BradinNC, kidcampbell71 and AndersF like this.
  30. 340HilbornDuster
    340HilbornDuster
    Couldn't remember how it went together.
    Found pictures way back in my post....
    AndersF likes this.
