Projects Project 29 Phaeton
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jan 29, 2013.
  1. 340HilbornDuster
    340HilbornDuster
  2. 340HilbornDuster
    340HilbornDuster
    Stogy, OahuEli, '52 F-3 and 2 others like this.
  3. AndersF
    AndersF
    Mowing along nicely now.
  4. 340HilbornDuster
    340HilbornDuster
    Thanks Man....
    Trying to get it running for this year's first local show....
    Registration or not.. !
    Still lots to do....!..just keep cranking!
    Sent from my SM-G930T using The H.A.M.B. mobile app
    Stogy and Dannerr like this.
  5. unie01
    unie01
    Loving this! sub'd[​IMG]
  6. 340HilbornDuster
    340HilbornDuster
    T'was my first fastening system...left it as decorational....actually works perfect![​IMG][​IMG]
    Stogy, OahuEli, AndersF and 1 other person like this.
  7. 340HilbornDuster
    340HilbornDuster
  8. 340HilbornDuster
    340HilbornDuster
    Stogy, '52 F-3 and AndersF like this.
  9. 340HilbornDuster
    340HilbornDuster
    That Hilborn likes fuel....
    The screw heads a homage to all the awesome electricians I work with.
    AND OF COURSE...reduced drag!![​IMG]
    Sent from my SM-G930V using The H.A.M.B. mobile app
  10. 340HilbornDuster
    340HilbornDuster
    Stogy, Dannerr and AndersF like this.
  11. 340HilbornDuster
    340HilbornDuster
    Some band Steel same width as the wood
    Original looling hook / strip.[​IMG]
  12. 340HilbornDuster
    340HilbornDuster
    Patching up the Fire Wall
    Used existing holes as a template. = mark cut from both sides..
    Stogy, AndersF and loudbang like this.
  13. rwrj
    rwrj
    from SW Ga
    This is just right. Thank you for posting all of it.
  14. 340HilbornDuster
    340HilbornDuster
    Stogy, LAROKE, AndersF and 2 others like this.
  15. 340HilbornDuster
    340HilbornDuster
    Last picture....
    BIG GAP...?
    1. Enlarge bottom firewall holes...slide to drivers side...
    2. Finally order one of those Stretcher / Shrinker...Shrink outer edge (sticks out!)
    3. Stick on rubber strips
    Should do it...?[​IMG][​IMG][​IMG]
  16. 340HilbornDuster
    340HilbornDuster
  17. 340HilbornDuster
    340HilbornDuster
    Fuel / Filter bracket.
    I leave out the High Pressure stuff in the picture....to be safe![​IMG]
    Stogy, loudbang and AndersF like this.
  18. Bam.inc
    Bam.inc
    from KS
    Tell us some wiring details on these two smaller batteries in-line, looks like a good space-saver, How's it gonna work (wire)?
    Stogy and loudbang like this.
  19. 340HilbornDuster
    340HilbornDuster
    If you put 2 6Volt batteries after each other (SERIES) You get 12volts - Same AmpHours.
    Put 2 6V batteries next (PARALLEL) You get 6volts. Double AmpHours.
    Stogy, OahuEli and loudbang like this.
  20. 340HilbornDuster
    340HilbornDuster
    I literally shaved off every mm including the filter brsckets....1/8 clearance on each side.
    Forgive me for the High Pressure stuff...[​IMG][​IMG]
    loudbang, patmanta and AndersF like this.
  21. 340HilbornDuster
    340HilbornDuster
    Starting to like painted stuff!
    Bent a bracket for the Ebrake, painted one side b4 I weld together.[​IMG]
    note: greased the bronze and plastic bushings...
    Stogy, Dannerr, loudbang and 2 others like this.
  22. 340HilbornDuster
    340HilbornDuster
    King pins, bearings, locks, shorten tie rod 1/2", shock mounts...maybe, nut & bolt locktight all.
    Paint radiator black....
    Lotso stuff left todo.[​IMG][​IMG]
  23. 340HilbornDuster
    340HilbornDuster
    Quick connector for front harness soldered. (disconnect when removing the body)
    Now I can start working on the wiring.[​IMG]
    Dannerr, Stogy, AndersF and 2 others like this.
  24. loudbang
    Dam I used to HATE those things. Try hanging upside down in the ****pit of a F-4 Phantom and removing the potting material and removing one pin and soldering in a new one and repotting. :rolleyes:
  25. OahuEli
    OahuEli
    from Hawaii
    Man how did I miss this thread? Subscribed!
    At least nowadays you can get them with crimp pins and sockets, no need solder. Great idea Tommy!
  26. 340HilbornDuster
    340HilbornDuster
    loudbang, AndersF and Tim_with_a_T like this.
  27. 340HilbornDuster
    340HilbornDuster
    Choice between silver and black.
    They're probably not going to look like that for too long.[​IMG]
    Stogy and AndersF like this.
  28. 340HilbornDuster
    340HilbornDuster
    Some DA, Etching Mag Cleaner,
    Etching primer + high heat engine paint w. Fins covered.
    Dust coat fins in all directions..(low angle).
    Doesn't look antique but it's better[​IMG][​IMG][​IMG]
    Dannerr, Stogy, AndersF and 1 other person like this.
  29. 340HilbornDuster
    340HilbornDuster
    Bam.inc, loudbang and AndersF like this.
  30. 340HilbornDuster
    340HilbornDuster
    Dannerr, Stogy and AndersF like this.
