Projects Project 29 Phaeton
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jan 29, 2013.
  1. 340HilbornDuster
    340HilbornDuster
    Got ****ered into buying one of these cameras on the Facebook ad for like 8 bucks.
    Everytime you push a ****on you get an ad to buy their software6 so you can use all the features.
    Handy tool though!
    It's really easy to look inside the engine.
    Made sure I installed the oil pump / pickup 20180606_195321.jpg
    Sent from my SM-G930V using The H.A.M.B. mobile app
  2. 340HilbornDuster
    340HilbornDuster
    OahuEli, loudbang, AndersF and 2 others like this.
  3. Stogy
    Stogy
    Now you can put your oil in...did you drop the pan, go thru the fuel pump hole or down the dipstick tube?
    Hey propeller striping...propwash commin up...
  4. 340HilbornDuster
    340HilbornDuster
    Needs a tune / clean up before I bolt it on.
    Those Stacks looks really funky.
    Anyone knows a good chrome shop?
    Any options?
  5. 340HilbornDuster
    340HilbornDuster
    loudbang and AndersF like this.
  6. 340HilbornDuster
    340HilbornDuster
    loudbang, Dean Lowe, AndersF and 2 others like this.
  7. Stogy
    Stogy
  8. 340HilbornDuster
    340HilbornDuster
    Hey Stogy, did you sneak in to my Garage last night..?
    loudbang and Stogy like this.
  9. 340HilbornDuster
    340HilbornDuster
    Much Better....
    Pressure washer
    Degreaser
    Etching mag cleaner
    Lotso scrubbing
    Any other ideas for that final Touch?
    loudbang, Stogy and AndersF like this.
  10. Stogy
    Stogy
    Only through fibre optics...:D...hanging around this place gives me digital opportunities to hopefully help you fellas with your vision moving forward. Can be a challenge getting things right too.
    My manifold is partially polished and aluminum looks great polished. Perhaps polishing the tops of the ribs and leaving the other surfaces with the bead blasted look...the tubes have plenty of pizzazz already. If you polish the tops of the ribs will you even see it?
    A full polish of the manifold is quite the undertaking but doable...I'm sure theres threads on it here...I received mine as is so someone else did the man hours and it looks cool. I remember a Hamber here many years ago a did a detailed thread on polishing axles and wow they were pretty awesome. I use Mag/Aluminum polish and it has some form of reaction with the aluminum and the results are favorable. I actually like the polished but left for a while look the most.
  11. Stogy
    Stogy
    The Final Touch cont'd
    This Hamber is no longer with us but perhaps a book may be available through someone who got one...
    https://www.jalopyjournal.com/forum/threads/metal-polishing-booklet.57098/page-3
    Hamber @Just Gary's thread on Valve cover polishing...
    very good info...and outcome...
    https://www.jalopyjournal.com/forum/threads/polishing-polishing-finned-al-valve-covers.97179/
    Hamber Dave Mann from Roadsters.com is quite accomplished in polishing and has some info which may be valuable if you should choose to do that...below is a post with some info to heed about polishing...he did amazing stuff
    https://www.jalopyjournal.com/forum...ng-finned-al-valve-covers.97179/#post-1152602
  12. 340HilbornDuster
    340HilbornDuster
    O2 bung ( like to know what's going on)
    Try to squeeze every inch, messed up the mating surface, added some more weld, grinded flat, done.
    Best way to learn is to screw things up!
    Stogy, AndersF and Dannerr like this.
  13. 340HilbornDuster
    340HilbornDuster
  14. 340HilbornDuster
    340HilbornDuster
    Poor man's water yet...
    Turns a 5 minute job into 5hours...
    Sent from my SM-G930T using The H.A.M.B. mobile app
  15. 340HilbornDuster
    340HilbornDuster
  16. 340HilbornDuster
    340HilbornDuster
    Viking spacer...
    First test ... stripped the threads in the pewter (not very strong)... epoxied in a nut.
    Put bearing grease on the bolt... 20180619_204055.jpg 20180620_184516.jpg 20180621_191538.jpg
    OahuEli, AndersF, Stogy and 1 other person like this.
  17. 340HilbornDuster
    340HilbornDuster
    The grill surround looked really grose...
    Had to F()€< it up s'more...
    Clear tomorrow, hope it doesn't rust.
    (It's not final paint...later!)
    AndersF, Stogy and loudbang like this.
  18. AndersF
    AndersF
    Glad midsommar.
    Happy mid summer.
  19. 340HilbornDuster
    340HilbornDuster
    Hi Anders! I'm coming over to your house!
    I know You'll have a HAPPY MIDSUMMER
    Hambers...This is some Real Swedish Stuff right here! Pickled Herring (I know you guys are just as excited as I am!)
    Bira, Dill Päran, 11 (ELVA) sorter me Sill!!
    Gräslök, Gräddfil, å "Den Lille"!...
    (Jag såg nåra matjes sill burkar på affärn för nån månad sen...kolla läget idag!)
    Happy Summer Solstice HAMBers!
  20. 27TV8
    27TV8
    Meget Meget fin mad! Looks like my lunch today. We drank all the Carlsberg so had to settle for a Molsens!
    Skal.
    AndersF and loudbang like this.
  21. 340HilbornDuster
    340HilbornDuster
    Trying to find an alternative to plastic tie wraps........LATER! 20180624_181609.jpg 20180624_151734.jpg 20180624_181548.jpg 20180624_181622.jpg 20180624_181701.jpg
    ccain, patmanta, loudbang and 2 others like this.
  22. 340HilbornDuster
    340HilbornDuster
  23. AndersF
    AndersF
    A bracket for a rod from firewall to radiator.
  24. Stogy
    Stogy
    :rolleyes:...Uhhhhh I dunno...o_O...I give up...:D
  25. 340HilbornDuster
    340HilbornDuster
    3 choices
    - Easiest - Modified the Model A (removed shifter housing. (Couldn't use my over engineered brake adapter)
    - Foot brake last swap meet...no space!
    - But. I got this cool 40 handle.
    BIG MAHALO TIM!
    ....Had to use it!
    Had this chunk of steel.
    Bracket is SOLID!
    "Beak " is supporting handle! 20180627_181850.jpg 20180627_183843.jpg 20180629_193831.jpg
  26. 340HilbornDuster
    340HilbornDuster
    Stogy, AndersF and loudbang like this.
  27. 340HilbornDuster
    340HilbornDuster
    - First picture was a fast way of making a fuel return line fitting...
    Stogy, loudbang and AndersF like this.
  28. 340HilbornDuster
    340HilbornDuster
  29. 340HilbornDuster
    340HilbornDuster
    loudbang, Stogy and Dannerr like this.
  30. 340HilbornDuster
    340HilbornDuster
    patmanta, AndersF, OahuEli and 2 others like this.
