Projects Project 29 Phaeton
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jan 29, 2013.
  1. 340HilbornDuster
    340HilbornDuster
    vking.JPG cowlx1.JPG cowlx2.JPG cowlx3.JPG 32brkts.JPG The Tudor got the viking so i got another one for the Phaeton.
    My Cowl Patches came out allright...just needs some grinding.
    Without the bottom part as a reference...
    ...i was a little out of alignment on the top...
    Now that the windshield stanchions are level...i messed up the p***enger side...got a new patch for $34 bucks on it's way.
    Next rear suspension...(need the rear axle to reference the rear wheel wells)
    Got some rear axle spring brackets from Speedway...They're allright...
    ...hard to find metal stock for a reasonable price over here...
    T
    volvobrynk likes this.
  2. 340HilbornDuster
    340HilbornDuster
    p1.jpg p2.jpg p3.jpg p4.jpg p5.jpg p6.jpg p7.jpg p8.jpg p9.jpg p10.jpg p11.jpg p12.jpg p13.jpg Back to work on the Tub.
    Cut the rear cross member and a bunch of different thickness boxing plates out.
    Even found some more diamond plate...What's up with this car and diamond plate?
    The 32 frame is of by inch and a half in the front!
    Ordered full boxing plates for reference and strength.
    Sketch of the style...little lower in the back...?
    It's my first full ch***is build so I'll just wingin it from here...
    T
    Tim_with_a_T and volvobrynk like this.
  3. 340HilbornDuster
    340HilbornDuster
    p1-1.jpg p1-2.jpg p1-3.jpg p1-4.jpg S'more Layout / Hight Tech Tools.
    Squared up the front end location...
  4. 340HilbornDuster
    340HilbornDuster
    s20130104_152727.jpg 20130104_165142.jpg 20130909_212758.jpg 20130909_212814.jpg Time to get the tub going.
    The frame is pretty much at ride height.
    front rails are off by 2inches! Firewall and back is leveled.
    Hoping to get a visit from DMV any day now,
    To make sure I have all the ducks in a row b4 I get started.
    T
  5. 340HilbornDuster
    340HilbornDuster
    f1.jpg f2.jpg f3.jpg f4.jpg f5.jpg f6.jpg f7.jpg f9.jpg fa.jpg fb.jpg fc.jpg Some progress:
    Welded the two frame rails together, squared them and started tweaking the rails. (Kick up in the back and front)
    They will be completely boxed w. fish plates & additional internal supports.
    With all that welding...I realized that I needed a frame table to hold everything in place!
    Luckily My buddy had one that I could borrow!..Thanks' Man!
    Time to give the back some rest before I continue!
    T
  6. 340HilbornDuster
    340HilbornDuster
    Phaeton B16.jpg Thanks to the frame table...everything is starting to come together...
    it's still in my head but, just gotta weld it in...
    & The frame is finally Straight!
    Here's what it may look like, except I don't think it'll have hood sides with the Hilborn.
  7. metal man
    metal man
    Funny, I was just thinking about this thread today while I was working on my phaeton, and here it is back on top. Looks like you are moving along nicely. I'll be watching this one.
  8. 340HilbornDuster
    340HilbornDuster
    f1.JPG f2.JPG f3.JPG F5.jpg F6.jpg F7.jpg F8.jpg Cowl is on the right position.
    Rear Wheels are centered in the wheel arch.
    Frame's pinched w. the Pinch O Matic (threaded rod)
    And all's level...
  9. 340HilbornDuster
    340HilbornDuster
    p1.JPG p2.JPG p3.JPG p4.JPG p5.JPG My pinched / Bob Bleed kicked (Just learned that's what it's called)
    frame fits the body contour Real Nice all the way back.
    The rear kick / pinch is pretty tight...but, tight is good.
    Next finish weld all the cuts and fill a bunch of holes!
    Put in som nut-serts and weld in boxing plates.
    Then it's time to get the engine / trans in there for fitment & start thinking about a cross member.
    T
  10. metal man
    metal man
    That style of frame kick up goes back to before Bob (or I) was born.
    Nothing traditional is new, right?:)
    The tub is looking good, man. Thanks for taking the time to do a build thread. I was too lazy to do one on my tub.
    Tman likes this.
  11. 340HilbornDuster
    340HilbornDuster
    340phaeton.jpg 340phaetonnh.jpg 340phaetonnhns.jpg 340phaetonnol.jpg With the 340..not sure about lake pipes...
    Don't think there's enough room inside with a pinched frame...
    T
  12. deucetruck
    deucetruck
    from Missouri
    Cool project! Your renderings really help visualize the build. Here's my thought:
    How about running a hood top and no sides? That way you keep that cool line of the body, front to rear, and still see your injectors?
  13. 340HilbornDuster
    340HilbornDuster
    340phaeton-hns.jpg deucetruck...That's it....
  14. 340HilbornDuster
    340HilbornDuster
    FA2.jpg FA3.jpg FA4.jpg FA5.jpg FA6.jpg FA7.jpg String? ch***is is sitting at 2 deg forward with these tires. (So I have to add that front end caster)
    Rear Axle set / clamped.
    Front suspension mocking....
    Spring behind, bones flipped, front x-member 3.5inches forward.
    Steering Tie Rod...Not sure where it'll go?
    I know I don't want it in front!
    The original steering arms is not going to clear the spring or go below...no matter how much I'd bend'em....got to lock around HAMB and see what other guys have done.
    I'll clean and sand blast the frame before final welding later.
  15. 340HilbornDuster
    340HilbornDuster
    RS1.jpg RS2.jpg RS3.jpg RS4.jpg RS5.jpg RS6.jpg RS7.jpg 32 spring holes too big....
    Made spacers from 3/4" EMT.
    Sliced about 3/16" off the middle.(two cuts)
    First picture = Cut too much out (didn't stay round)
    2nd picture = just enough (Round + Fit bushings perfect!)
    Did the second one the same = round.
    To try to measure spring hangers at 15 deg. angle is tuff.
    I have to use the spring as a template...
    Then I must have is a spring spreader!...a 32 spring spreader.
    Some bed frame angle iron and two cut down hinges + threaded rod)
    How did I come up with this idea?
    (Some Dude here on HAMB gave me the idea...Thanks Dude!)
  16. metal man
    metal man
    I think you'll find that you need longer steering arms to get the tie rod behind the spring. That's what I had to do on mine. I've got the spring behind the axle like yours . I will try to remember to post pics tomorrow...got to get to bed .
  17. 340HilbornDuster
    340HilbornDuster
    r1.JPG r2.JPG r3.JPG user10099_pic436114_1356926478.jpg Finally got the rear axle out...barely...small garage, lot's o ****, frames etc.
    Cut the spring brackets off.
    Mopar Factory Welding:
    The brackets had really bad welds (parts of them not even attached to the axle) good for me!
    Side Note: My Charger's body seams had more MIG whiskers than the musical Cats.
    Dry fit:
    The axle & spring is upside down, brackets right side up.
    Now I just have to eat my spinach & "thread" the axle back in again.
    Metal Man.
    I checked out your pictures. (Awesome work!!!)
    - steering arm drop jig 001
    - Lengthened and gusseted steering arms for spring behind axle on the Phaeton
    - tub spindles 003
    LAST PICTURE'S METAL MANS!
    I put it in for others to see...cause it's purdy!
    If i don't go back, like yours, I may go down below the bones...pends on where my spring ends up.
  18. metal man
    metal man
    Oh, thanks, I'm glad you found them. I didn't even realize there were already pictures of them in my albums.
    Your car is coming along nicely!
  19. 340HilbornDuster
    340HilbornDuster
    c1.jpg c2.jpg c3.jpg c4.jpg c5.jpg c6.jpg c7.jpg c8.jpg c9.jpg Took the frame out of the jig...
    Paint stripped the inside...easy to sand blast before welding later.
    (Wonder who drove an orange hot rod in Hawaii way back?)
    This is what the sky looked like outside the garage today....!? *side note*
    I slid the rear axle back in again on a Rail...Back one had some old welds on it...
    The whole frame table moved 2 inches...squared right back up again..
    Rear axle jig / compressor in place...I'm still only at 26" perch distance.
    Maybe that's why guys use the Model A spring...?
  20. 340HilbornDuster
    340HilbornDuster
    RA 1.JPG RA 2.JPG RA 3.JPG The 32 rear spring have been fighting me back so far.
    - Spring shackle distance doesn't make sence...
    - It's sitting funny in the ch***is...
    - The Cross member's too short... 40" wide...Rear frame rails are 43
    Decided to Measure the Model A cross member...43 inches.
    Maybe It's trying to tell me something!
    Took it apart (still amazed that bolts from 1928 still works great with a little heat)
    I'll Clean it up tonight and try it out.
    Maybe this is why few guys are using it in Hot Rods?
    We'll see where it goes?
    T
  21. 340HilbornDuster
    340HilbornDuster
    FE1.jpg FE2.jpg FE3.jpg FE4.jpg FE5.jpg RODENDS.jpg "It's called research, when you don't know what you're doing"
    It is my first full frame build after all...
    Had to move the "Pinch O Matic" cross bar so I can lift in the engine and trans for fitment...
    So I came up with these adjustable mounts...
    Only Problem, Now I can't put the body on the frame.
    Keep on winging it!
    There's a lot of stuff on a front end the wants to share the same space.
    I'll probably move the spring forward and lengthen the steering arms (like Metal mans)
    Tie Rod Ends:
    Did a little calc. on the load on the Tie Rod ends.
    They should be able to hold up ~250 lbs...?
    T
  22. 340HilbornDuster
    340HilbornDuster
    BS1.jpg BS2.jpg BS3.jpg BS4.jpg XM1.jpg BS5.jpg BS6.jpg BS7.jpg BS8.jpg BS9.jpg S'more progress...
    I don't know how Henrys guys welded these bones..?
    They had this soft solder looking stuff inside 'em...
    Moved the front cross member forward...looks a lot better.
    The Tie rod can now go behind the spring & it'll also reduce
    the load on the Bone joint...(tie rods)
    Welded the bones in three p***es...
    T
  23. 340HilbornDuster
    340HilbornDuster
    TE1.jpg TE2.jpg TE3.jpg Got the Tie Rods re-built ... needed to cut the edges in the lathe to pop 'em together...took me a while to figure it out...
    Made a tool out of an old socket.
    Thanks Vince76 for the ends...they're nice.
    My borrowed ones look thicker but they're the same outside diameter.
  24. 340HilbornDuster
    340HilbornDuster
    BS1.JPG BS2.JPG BS3.JPG BS4.JPG BS5.JPG BS6.JPG BS7.JPG BS8.JPG So much for having a rolling ch***is by the New Year...
    But it's getting there...
    The taper sleeves will be welded to the frame and go throught the boxing plates.
    Got these ****py perches with an arbitrarily angled allen bolt welded to them from somewhere...(Speedway I think)
    They don't look very strong so I'll try to use the cut off perches...straightened them out a little...we'll see?
    Happy New Years!
  25. 340HilbornDuster
    340HilbornDuster
    MB1.jpg MB2.jpg M1.jpg M2.jpg M3.jpg M4.jpg Been Working on the front suspension...
    Tried to use a 31.5 inch reverse spring with a Ch***is Engineering front axle...(long side track...)
    Decided to order a 29 inch... It will clean it up / look a lot better!
    Got the body back on.
    Modified the adjustable rail bracket so there not in the way.
    Since there's no bottom in the body I had make some adjustable brackets to hold it up in the back.
    Engine and trans in...yes I'm going to run an automatic (manual valve body)
    Have to set all the angles so I can start working on the rear axle...
    Boxing Day:
    Then I have to decide if I'm gonna box the rails first or put the cross members in and then box'em...
    I think I'll at least weld in the front and rear cross members before boxing it..?
    Any pros & cons?
    T
  26. 340HilbornDuster
    340HilbornDuster
    Holy Bones.JPG Received my 29" reverse main leaf from "Johnny Law"...?
    (the only place I could find one...and the only thing I really wanted from them)
    Anyways the spring is a HELIX brand. (made in china)
    Anyone used HELIX suspension stuff before?
    The eyes are really loose...Pete & Jakes bushings are kind of floppy in there - I'll see if I can adjust them in the vice.
    Started the layout of the spring attachments on the bones and figured I better drill the holes at the same time.
    I'm using 1" (1.063" ID) & 3/4" ( 0.863" ID) Rigid steel conduit to fill the holes.
    I think I'm going with the 2.5 inch CC layout.
    Maybe I'm overdoing it but..."If it's worth doing, it's worth over doing"
    T
  27. daddio211
    daddio211
  28. 340HilbornDuster
    340HilbornDuster
    sp1.jpg sp2.jpg Thanks Daddio!
    I should have asked the HAMB gang first....
    Here's a real spring compared to a HELIX spring.
    No wonder the spring eyes are loose.
    I'm going to send this **** back to Johnny Law.
    I don't want to trust my life to this $#!t
    Does anyone know where I can find a real 29 inch reverse main leaf spring?
    Reading a lot of posts here on HAMB...sounds like Hoffman stuff is all ****!
    (I didn't see Hoffman or Johnny Law listed as alliance members)
    Here's a link to keep track / avoid their ****!
    http://www.thehoffmangroup.com/
  29. 340HilbornDuster
    340HilbornDuster
    b1.jpg b2.jpg b3.jpg b4.jpg b5.jpg b6.jpg b7.jpg Got the bones laid out (went with 2.5inch center between the holes)
    Need to get some rigid conduit s**** from work this week to do the holes.
    My drill was to fast for the big size drills so I had to set it up in my Hobby Smithy.
    Spring perches:
    I liked the idea (got it from someone here on HAMB!) to have them loose both ways...easy to adjust angle and shackle spread.
    When done, weld the inside...cut the outside and weld it.
    T
    OahuEli, Atwater Mike and volvobrynk like this.
  30. daddio211
    daddio211
