Projects Project 29 Phaeton
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jan 29, 2013.
  1. patsurf
    patsurf
    paint some frets and strings on that!
  2. 340HilbornDuster
    340HilbornDuster
    HELP! Any ideas!
    I had to replace the hoses and the new hose connectors are a bit taller,
    So i had to replace some of the AN-4 straight fittings with 45's for clearance.
    They do Not seal! on the NPT side...maybe the threads are slightly smaller.
    I tried Permatex Avionics gasket sealant. (for gaskets, threads, 1000psi, Gasoline / Alky safe.)
    Didn't work
    It's Aluminum to aluminum.
    1. I may try to TIG'em on?...(after i clean that goop off)
    2. Maybe ask a Machinist or "cut n send" to make some new ones. # $$$$ !?
    I've driven it a bunch B4 and On / Off a couple of times)
    never had Any problem with leaks!
    Any ideas help!
    YT -
    https://www.youtube.com/@73cuda340hil/featured
    Tim and 2Blue2 like this.
  3. 340HilbornDuster
    340HilbornDuster
    I like the lighter style too some black fades at the edges...
    Tim, guthriesmith, 2Blue2 and 2 others like this.
  4. 340HilbornDuster
    340HilbornDuster
    Supposed to be the 30's Indy car V8 logo ... more towards the front.
    Maybe darken the circle to look like a sound hole...?
    2Blue2 and AndersF like this.
  5. AndersF
    AndersF
    That sunburst ide really have potential to look great.
  6. 340HilbornDuster
    340HilbornDuster
    Thanks Anders!
    I've ONLY found one car with a real sunburst - faded to dark at the edges.
    I like it!
    This is not a Sunburst in my mind...because it's a fade in a box.
    Sharp edges.
    Now i just gotta do "some body work" and start practicing the Winfield Fade technique...
    AndersF and 2Blue2 like this.
  7. 340HilbornDuster
    340HilbornDuster
    Found out it's the AN side that is leaking! Not the NPT side.
    Fortunately br*** is harder than aluminum so my new hoses should still be good?
    Check out my test rig.
    Never would have found it in the car.
    https://youtube.com/@73cuda340hil?si=aX1BIIvWe44_2lVR
    Shorts section.
  8. 2Blue2
    2Blue2
    Loving the sunburst idea and you presented it so convincingly. Like the Triumph fade.
    Gene would like this idea too.
    You Will need that gold exhaust though.
    Have burst painted a few my self...
  9. 340HilbornDuster
    340HilbornDuster
    Wow...that is CL!
    Did You use "paint" or like a "tint" semi clear stuff for your fades?
    2Blue2 likes this.
  10. 2Blue2
    2Blue2
    I Use Mixol and Transtint set in clear gloss lacquer w/airbrush to 'fade' then clear over top with gun.
    This set up is very prone to quick UV fade and lacquer is famous for premature aging which might be desirable occasionally on guitars but less so for cars.
    For fast 'real UV fade' I spray with tint in just Thinner, one day in Hawaiian sun, then clear.
    07roCgQ0QUSCpYtVJcSwiQ.jpg IMG_20160429_133006282_HDR.jpg _storage_emulated_0_DCIM_Camera_IMG_20160429_150231545_HDR.JPG
    AndersF likes this.
  11. 340HilbornDuster
    340HilbornDuster
    Again...Wow that's a Really Nice Fade right there!
    I had no idea this was your "specialty"...
    Are You a Luthier / Do you build guitars?
    Test Paint:
    I was going to do a test run with rattle cans...solid paint.
    But as you can see on my gas tank...it's not very nice / fadey...
    Probably make it look like
    Tint:
    Do you know a good place to buy tints? On Oahu??
    2Blue2 likes this.
  12. 2Blue2
    2Blue2
    No not a real luther, I'm just some old guy glueing boards together in the garage.
    yes i built those guitars and am slowly getting better at it.
    Nice fade hard to do with spray cans or opaque paint, but like Gene Winfield said
    "I just keep painting till I like it.'
    Those tints came from woodcrafters here on island Hard to get shipped being hazardous and all.
    Favorite auto paint store- Highline and they carry Lil Daddy Roth stuff so once you see the pearls and flakes... I got the flake gun, and as soon as your ready for giant 70s b*** boat flake, candy pearl, rainbow, hotrod goodness.
    I used to paint on cars and to execute your idea I would use a touch up gun and a quart of each color and since fade is hard to spray for shine/flow or cut/buff it would need clear coat.
    Of course F all that and just spray bomb it, and next year do it again different, so the old gal gets a new dress for spring.
    present koa top project thats keeping me from me hotrod.
    AndersF likes this.
  13. 340HilbornDuster
    340HilbornDuster
    Hi Dude
    You "Glued those boards together" huh...
    Those are Works of ART Man! I Don't think i ever seen a KOA guitar B4!
    Gold bridge and Pickups etc.
    Thanks for the Pep talk!
    One day I'll get around fixing some of those holes. (no perfect gap body work here...) It's a Hot Rod!
    And then I'm just donna "Paint it till i Like it"
    Something like this maybe...?
    My wife's an artist so She's always there for support.
    tim troutman, Stogy, 2Blue2 and 2 others like this.
  14. 2Blue2
    2Blue2
    This latest pics pretty good
    Have Ai paint the rollbar gold and suspension /steering black or red
    V8 logo is awesome. Definitely do that.
    Wifeys outfit matches car, why dosn't yours?;)
  15. 2Blue2
    2Blue2
    Got me staring at some Winfield fades, especially orange ones...
  16. 2Blue2
    2Blue2
    Likey theses...might try to do someday.
    41sedanetteowner likes this.
  17. 340HilbornDuster
    340HilbornDuster
    Since (obviously) : No Windward Winfield I ain't - can't even hide my "body work" with Bondo & Paint
    ...One day i get the courage to do the Sunburst Fade.. (maybe there's one someone on the Island...something Blue?)
    Meanwhile - I'm gonna stencil these (the coolest flames on Earth)...And paint it off white for now
    a[​IMG]
    Original - one of my all time favorite Hot Rods!!
  18. 340HilbornDuster
    340HilbornDuster
    This one is PERFECT!
  19. 340HilbornDuster
    340HilbornDuster
  20. 340HilbornDuster
    340HilbornDuster
    Varnish removed from tank...along with the Red Kote inside...No Leak!
    Tank repainted outside. New REAL Buffalo Hide belts...shouldn't crack?
    New Brake switch bracket? old pressure switch type "popped the top"
    = big leak - I'm dun with that type!
    Painted the temporary floor boards...lava lining under side.
    Polished up the 'Speed King"... was looking real sad!
    Have to polish headlights and some other few shiny bits now.
    The whole fuel system flushed. New *fuel sprayers* New "Hats, fittings & hoses.
    NO PICTURE!
    Time to get that late Safety Check...
    AndersF, Stu, porkshop and 1 other person like this.
  21. 340HilbornDuster
    340HilbornDuster
    The $700 bucks start...1-2013
    6687a6d8-a842-4c27-b813-fe3b612adb88.png 3af5e93a-6156-43c1-8137-2517435ed68d.png
  22. 340HilbornDuster
    340HilbornDuster
    That fancy Gold paint was ****...never cured. Then burned & molded!?
    Waz Next?
    Powder coat...? Is that a Good idea?
    Or just like this w WD40...
