Project 29 Tudor in Mass.
Discussion in 'Traditional Hot Rods' started by Mikel50, Apr 17, 2015.
  1. Mikel50
    Mikel50
    I got the sliders already on both of the fronts.
    (In that picture.)
    I used a set from a set of Jeep Wrangler YJ seats I had.
    I had to cut 3” off the total length.
    Also the p*** Jeep seat has a hinge mechanism to tilt the seat forward. Basically have it set up so the p*** front seat will tilt forward to the dash and lock back on the floor.
    I’ll post up pics once it’s done ...It’s nice and clean so far.
    The steel structure is just 1” box. Nothing fancy and nothing I can use. (At least on the car I mean)
    I suppose I could use it but it was more work than I wanted to put into it.
    Bolts were all rusted in the floor of the bus.
    The seats were worth the price of admission [emoji16][emoji1360]
  2. 28TudorAZ
    28TudorAZ
    For the back seat I would just make wooden frames and have someone put foam and upholstery on it. I may take my back seat in and have them replace the springs with foam.
  3. Mikel50
    Mikel50
    These seats are steel framed done ... absolutely no modifications needed.
    I mocked up a set of feet for the front and a set of tabs off the back.
    Couldn’t have been more simple.
    patmanta, brEad and JOYFLEA like this.
  4. Mikel50
    Mikel50
    Nothing to see here ... just building a 1950’s hotrod [​IMG]
  5. sloppy jalopies
    sloppy jalopies
    buicks and shoebox ford spare covers were about 1" wider... HIH...
    Mikel50 likes this.
  6. Mikel50
    Mikel50
    These are 35-36 I believe ... so you’re telling me I need to spend more money.
    Anyone need a kidney ?
    brEad and spurgeonforge like this.
  7. sloppy jalopies
    sloppy jalopies
  8. JOYFLEA
    JOYFLEA
    I might need a liver sooner or later.
  9. Mikel50
    Mikel50
    Smitty,
    I don’t think these are 35-36 Ford. I have 3 sets of fenders (rings) and they’re all different widths and have different bead profiles.
    These are the widest by about an inch.
    May be what you had mentioned previously.
  10. Mikel50
    Mikel50
    Got the the drivers seat sliders and mounts all situated today plus got the p*** seat slider ****oned up.
    I’m about half way through mocking up the hinge mechanism and rear locking mechanism on the p*** seat.
    The low profile required with the chop and channel is not leaving me much room... But I have it worked out and hoping to ****on it up over the next day or two.
    Everything is fabricated out of the Jeep seats mounting brackets sliders and hardware.
    If you didn’t know they were there you wouldn’t ever see them...Just how I wanted it.
    Seat slider Handle sectioned to 5”
    Portion of the p*** Jeep seat frame
    Cut to make mounts for the drivers seat.
    Tacked in place
    [​IMG][​IMG]
    Seat with sliders all the way forward.
    Seat with sliders moved all the way back
    Doesn’t get much better than that ... a total 6” of seat adjustment
    Plus it’s nice and clean just how I wanted it.
    Onward [emoji1371]
    brEad, chop job, Aaron D. and 12 others like this.
  11. vtwhead
    vtwhead
    Nice! Great work, seats are trick.
    Mikel50 likes this.
  12. panicmike
    panicmike
    I even like the color
    Sent from my SAMSUNG-SM-G930A using The H.A.M.B. mobile app
    Mikel50 likes this.
  13. Mikel50
    Mikel50
    Some things just work out [emoji1360]
  14. Wheeliedave
    Wheeliedave
    Mike, your imagination and work are simply outstanding!
    I hope to be able to use some of your ideas as I work on my car. Dave
    NashRodMan and Mikel50 like this.
  15. SquintBoy
    SquintBoy
  16. Mikel50
    Mikel50
    Thank you so much. I keep saying it but I am having the time of my life. It’s something I’ve always wanted to do. I’m driven to learn and build a car others will appreciate.
    I can’t wait till the next one [emoji16]
  17. Aaron D.
    Aaron D.
    Great job on the sliders Mike.
    Mikel50 likes this.
  18. mike bowling
    mike bowling
    Yup- dig up another can...
    Looks real good!
    Just don't put a stripe down the middle of your roof to match the seats, and a surfboard on top- Cowabunga, Dude! Like totally gnarley!
    patmanta and Mikel50 like this.
  19. Mikel50
    Mikel50
    I was just starting to like the red stripes too ... [emoji41]
  20. general gow
    general gow
    MODERATOR
    yup that's my car.
    chryslerfan55 and mike bowling like this.
  21. Mikel50
    Mikel50
    Group effort Friday/Saturday got everything figured out and got my car steering.
    Sold a bunch of things locally and on eBay lately to keep things moving.
    Replaced the poly tank that came with my car with a 14gal Tanks Inc fuel tank.
    Ordered a chopped radiator last week so that should be arriving soon
    Ordered the remainder of brake and fuel system needs.
    Fuel Pump,lines, fittings, proportion valve and residual valves ...blah blah.
    Opted not to run 4 buckets and went with my initial plan w a rear bench.
    Making adjustments to run it with the stepped rear at the moment
    Not a lot of progress pics but there is certainly progress being made.
    [​IMG][​IMG][​IMG]
    Did some tool flipping to eventually end up with a horizontal bandsaw and a bunch of other handhelds for the shop
    I turned a $50 vintage lathe purchase to what you see in that picture [emoji1362][emoji16]
  22. Mikel50
    Mikel50
    Ordered my 39 3:78 rear axle/pinion rebuild kit this am and hoping to have this one completed and under the car in the next couple of weeks to get it rolling with all the final components.
    I also created a new friend for the garage ... she keeps my beer cold [emoji847] [​IMG]
    Till next time [emoji1366]
  23. patmanta
    patmanta
    from Woburn, MA
    Nice progress, Mike.
    Heads up on the DeWalt 18v stuff, I have discovered that they make adapters to run the 20v batteries on the older 18v tools. So if your 18v batteries are tired (which mine are after 5 years of use) you can spend the same money on better batteries. I think they work up to the 5ah size but the 6ah ones are not recommended and have a casing that won't allow them to work with the adapter. There's also a warning about using the bigger batteries with some of the drills but it's still a bargain.
    chryslerfan55, JOYFLEA and Mikel50 like this.
  24. Mikel50
    Mikel50
    ThNks pat. I charged them all up early that day and they all seem to hold a charge thus far. I'll refer back to your link if need be in the future.
    chryslerfan55 and patmanta like this.
  25. patmanta
    patmanta
    from Woburn, MA
    Good plan! i'm looking onto upgrading and expanding my cordless collection and the nice thing about those things is that you can keep all your older stuff going with the new batteries. They also make bootleg made in china 18v batteries now for about $35/pr but mileage may vary on those!
    HNNNG!:
  26. Mikel50
    Mikel50
    I honestly didn’t need them because I have pneumatic tools now. But everything dewalt was $50. Couldn’t p*** it up
  27. Mikel50
    Mikel50
    Avoiding shoveling the BS falling from the sky I locked myself in the shop and sorted out the rear seat. Picked up a Chrysler T&C 3rd row seat. Had to modify the base to fit with the rear crossmember. Took some time but I’m happy with the final result.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    At this point I need to make mounts for the rear and bring the seats to the upholstery shop.
    Oh boy ... that’s going to be surreal.
    Enjoy fellas !
  28. tb33anda3rd
    tb33anda3rd
    i like the bench seat much better in the rear. looks more finished.
    Mikel50 likes this.
  29. Mikel50
    Mikel50
    I have to agree.
    I was tossing the idea of the buckets early on when I found them, but in the back of my mind knew it wasn’t period correct.
    I couldn’t bring myself to use them.
    This seat will get reshaped to match the flatness/shape of the front bus seats.
    tb33anda3rd likes this.
  30. Mikel50
    Mikel50
    Made the first seat mount from the leftover 1/2” X 2” channel I used for my floor structure.
    Trying to make it look like an old cast part and not something made from new channel stock.
    Still need to clean it up a bit... but I’m happy with the look.
    [​IMG][​IMG][​IMG]
