Projects Project 333 [Half Evil] a Mid Engine Roadster DragCar started finally.
Discussion in 'The Hokey Ass Message Board' started by Littleman, Dec 31, 2011.
  1. 56gasser
    56gasser
    from lower al.
    You'r a sick Littleman!!LOL!! Just like the rest of us.....
  2. shane85
    shane85
    wow dude! rad! What kind of Tig machine do you use?
  3. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Shane85, I use an older Miller DialArc HF machine w/ cooler....one day I need to take a real welding cl***..I remember the day I brought it home.......had no clue how to make it work.
    Metal Meltdown, Yes, I plan on adding gussets ect.....I am far from done..I just got it far enough along to set it on the ground for a look see......It is going back on the table...I need to finish mounting everything then add my additional protection.
    Thanks everyone, today was a good day for me....I have been waiting to set it on the ground .........Trust me..I stand back and stare at it and just scratch my head...probably the same thing everyone else does after they look at the pics I posted....Ha ha...but I keep going forward......Littleman Dave
  4. Royalshifter
    Royalshifter
    Moderator
    Really looking good Dave.
  5. slobroy
    slobroy
    Looks good Dave. Sooo is the drags in Bowling Green next fathers day gonna be in your plans for this ride?
  6. slobroy
    slobroy
    Looks good Dave. Sooo are the drags in Bowling Green next fathers day gonna be in your plans for this ride?
  7. Saxxon
    Saxxon
    Wow... just wow
    Can't wait to see this thing scream under it's own power
  8. swade41
    swade41
    from Buffalo,NY
    Unreal.......The side of that scoop needs an Ed Roth style head, googly eye ball and mouth with a big tongue blowing towards the rear..lol
  9. TexasSpeed
    TexasSpeed
    from Texas
    Wait a minute. You got this thing on the ground and the body on it..
    Where are the "vroom-vroom" with you sitting in it pictures? That's kinda mandatory, you know!
  10. Scrap Iron
    Scrap Iron
    from Mesa, AZ
    Gulp, that is awesome...
  11. neverdun
    neverdun
    Looking *****in. Can't wait to see whats next.
  12. Shane Spencer
    Shane Spencer
    awesome work dude....
  13. jfrolka
    jfrolka
    Speed sport
  14. perkshotrods
    perkshotrods
    Great thread. Amazing work. I look forward to seeing this thing run.
  15. Mattbee
    Mattbee
    This thread is awesome! The car has a stance/look that looks so right! This thread gives me a lot of motaviation for my build! Your fab work is awesome!!!!!!
  16. patman
    patman
    At this rate TLC/Discovery will be doing a show to see if Jimmy Shine can make the cut to work at YOUR shop!
    Amazing work...inspirational...thanks for including us!
  17. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Thanks everyone..........I am super stoked to see it sitting on the ground and an official roller. I have it back up on the table....time to figure out front shocks, steering and front panhard bar locations and mounts along w/ a few more ch***is structural tubes..........Littleman
  18. Derek Mitchell
    Derek Mitchell
    That car is awesome. I love mid engine roadsters, either for drag or land spped.
    Keep up the good work.
  19. scootermcrad
    scootermcrad
    Hooooolllly...... WOW! Haven't checked in on this thing in awhile! Looking incredible, Dave!
  20. Dave- time to put your big boy fire boots on.. ha ha ... Looks killer my friend..
    T.H.
  21. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    We can race !.............Littleman
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
  23. Sparkswillfly
    Sparkswillfly
    from Colorado
    This is going to be awesome.............!
  24. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I finally got the rack mounted..I made the mount the way I did.... to help tie the front end together even more and make it stronger..I will only be using the one side of the rack w/ a tie rod like in a cross steering capacity.....The other side I will trim down and fab up an aluminum cover of some sort..The main steering shaft will be fairly short and will have a U-joint along w/ the anti push back sleeve I machined on the lathe in place near the main steering wheel mount...Littleman
  25. That rack setup is sweet! I'm a little concerned about bump steer if that thing gets a lot of nose lift on launch. That is a pretty short tie rod...
  26. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I have not mounted the upper shocks yet........I plan on limiting the axles unloaded drop travel, while in concert w/ a well placed and adjust wheelie bar.....I understand the trouble caused by a ch***is mounted rack and the changes it can cause during movement. If it gives me trouble, ''have welder can fix'', as I always say. I did have a good conversation w/ ch***is builder Rooman before going this route.....I guess I could have mounted the rack off center to make the tie rod longer......as it sits now, their is no bind when turning and playing w/ a jack under the axle w/ the ch***is clamped down w/ all the connections oriented correct....But I need to mount the upper shock position to control the total axle drop............Thanks for the info...Dave
    I will add...this is one of the reasons I like to post a thread build, one it forces me to do***ent the build and since I never built anything like this it allows some w/ more knowledge to add some useful info ! Because I will be the first to admit...I have no idea what the hell I am doing...
  27. Oh, I wouldn't say that...
  28. Saxxon
    Saxxon
    Pretty professional looking for someone who doesn't have an idea what they are doing. History has shown many times that one man's stumble into the unknown is equal to other men's genius. It all depends on talent desire and the willingness to take that first step. It also helps when you have all the tools (sic)...and did I mention the talent ?
    Unbelieveable build Dave. I'm thinking your workload might increase substantially after this build (and DDS... if you ever finish it) Having said you did the work would be bigger in my books then saying it was done by Trepanier, ****era or anyone else. (Ok maybe not ****era...)
    Keep on keeping on...
  29. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I have the steering mocked up and made some additions to the front of the ch***is....built in another foot box area just a few inches back from the original one which is the very front of the ch***is. I still have a few more bars to add which will include mounting the steering shaft support............Littleman
  30. Nice work! I've been following this build for a while now. I can't wait to see the finished product, defiantly gonna be cool.
