Projects Project '38 Update
Discussion in 'The Hokey Ass Message Board' started by Ryan, Jul 17, 2013.
  1. Ryan
    Ryan
    ADMINISTRATOR
  2. That is a nice solution.
  3. Jeff Norwell
    Jeff Norwell
    MODERATOR
  4. seadog
    seadog
    Hey Ryan, check your PMs
  5. Abomb
    Abomb
    A very clean, thinking outside of the box type solution...
  6. chigger
    chigger
    I must be missing something or I am just a dumb ***. I that for the through bolt for the spring pack?
  7. druids62
    druids62
    I'm not certain if I follow as well.
  8. Tim
    Tim
    from KCMO
    ok guys instead of the U bolts holding a pad under the spring they added some meat to the cross member and the pad bolts in front to back threw the cross member nice and flush thus keeping the pad and ditching the u- bolts.
    ya gotta look at it a few times to catch it
  9. Ryan
    Ryan
    ADMINISTRATOR
    Exactly.
  10. Bigcheese327
    Bigcheese327
  11. thunderbirdesq
    thunderbirdesq
    Looks nice, So... does the taper on the head of the bolts draw the block tight enough against the spring? I was taught that U bolts are substantial in size in order to clamp the spring in place to prevent crossmember cracks and leaves from cracking due to over flexing at the center bolt.
  12. flt-blk
    flt-blk
    from IL
    Is the spring still pushing on the underside of the crossmember like stock, or is it hanging above the spacer by the centering pin?
  13. VoodooTwin
    VoodooTwin
    from Noo Yawk
    To add to this, and this is an ***umption so correct me if I'm wrong: the spring pack will be securely bolted to that meaty pad first, then attached to the crossmember with those 4 flush bolts?
    I dig it. Clean and simple. The only possible draw-back to this design is there is no means to "level out" the front end to account for any right-left weight distribution delta. I like to play with the u-bolt torques to accomplish that. I guess shims could work instead though.
  14. Jkustom
    Jkustom
    Holy **** I never would have thought of that.. Awesome. Really cool. I really look forward to the updates on this car.
  15. truckjim
    truckjim
    Quick note. Love having the 'accessories' mounted low so the engine is the star. Fought to do it that way on my truck. Nice solution to the spring mount clearance issue. Use #8 or better hardware and should be good.
  16. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
  17. draider
    draider
    from Texas
    Hot Rod Pro does a similar set up by welding tabs to the cross member and running the bolts vertically. Keith's way looks pretty stout and clean.
  18. pumpman
    pumpman
  19. hmm why not through bolts front to rear...???
  20. Hitchhiker
    Hitchhiker
    How does that ****er tighten the spring in the pocket....not sure I get it. Looks CLEAN though.
  21. alchemy
    alchemy
    I still don't understand. What "clamps" the spring up into the U of the crossmember? I see it won't fall out the bottom, but what holds it up tight? Is there just a pack of shims between the bottom of the spring and the new plate?
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Screw the Mount...give us the skinny on the internals of the Y-Block:)
  23. Gunpilot
    Gunpilot
    from Tennessee
    Yea, I don't get it either. But I'm sure it must be obvious or everyone else wouldn't be raving over it? Maybe a photo with it all mounted up would make it all clear?
  24. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I had to pie cut and section my oil pan to clear it in my '35. It was tight after an old repair which consisted of welding 1/4" plate to the top of the crossmember to fix a common crack.
    I like progress!
  25. Ryan
    Ryan
    ADMINISTRATOR
    It's super simple... I'll reprise this post on final ***embly with an image of how it all goes together.
  26. Baumi
    Baumi
    That´s a great solution... It took me a while to figure it out, but i finally made it:)
  27. F&J
    F&J
    Ok, I hope I don't end up on the S--- List, but I can't see this working on something that will see a lot of real road use. Racecar, yes.
    Like Tbirdesq mentioned, there is a boatload of stress at the center mount, especially on any body roll or dips on one wheel. We tend to forget that 100% of all jolts and road vibration put on the front half of the car, concentrate right there. I just can't see those tapered allen heads staying tight. One poster alluded to that by suggesting through bolts and nuts instead.
    I realize the pic of the mock up motor is probably just sorta close to where it will finally mount up, but even custom made "flattened top" U bolts really don't use up much room. Maybe i am missing the main reason why the motor could not be moved a tiny bit, to allow flat top/band top, U-bolts..... But I do know when it comes down to not wanting to cut a firewall, or hood clearance, then we get stuck doing something we'd rather not do.
  28. I understand how it works,
    pretty slick.
    I would have gone with steel though.
  29. Boones
    Boones
    from Kent, Wa
    will the spring pack bolt go up thru the crossmember. if not, are the 4 (2 front and 2 rear) strong enough to hold the spring pack in place under rough driving conditions (pot holes exc...) I like the idea though.
  30. 1964countrysedan
    1964countrysedan
    from Texas
    Good! Because I too am in the "huh camp".
