Projects Project '38 Update
Discussion in 'The Hokey Ass Message Board' started by Ryan, Jul 17, 2013.
  1. F&J
    F&J
    If the tapered holes are positioned correctly, and as you tighten them, the tapers shove the aluminum block upwards as the taper bolt finally seats to the tapered hole.
  2. 1964countrysedan
    1964countrysedan
    from Texas
    It certainly helps when you can see the springs.
    Thanks
    looks safe enough for Ryan to ride in
  3. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I'd be stripping out the allen heads or the aluminum threads for sure, lol.
  4. I will let it be known that I have not posted on this thread. ****
  5. Ryan
    Ryan
    ADMINISTRATOR
    Ya'll are funny... :)
  6. ShiftyRat
    ShiftyRat
    Some design, some drive...
  7. Krash
    Krash
    from Cleveland
    This **** is funny!
  8. Crusty Nut
    Crusty Nut
    I've had this happen before too. Showing off something that works as designed, only to be bombarded with comments about all the ways it might kill you.
    Looks good from here.
