Projects [PROJECT] Laidout53 Part II
Discussion in 'The Hokey Ass Message Board' started by HarborKustomSpeedShop, Oct 11, 2010.
  1. -Brent-
    -Brent-
    Your work is super clean, I enjoy watching the progress. Nice job.
  2. HarborKustomSpeedShop
    from Olalla, WA
    Thanks guys, means alot...
  3. Still can't get how quickly you're making progress.
    You'll have a full frame project done before I can get a 'simple' engine swap done on my truck.
  4. hudsoncustom
    hudsoncustom
    Nice work laidout...I don't know how I missed this thread the first time through.
    You've got ambition and skills, that's for sure.
  5. HarborKustomSpeedShop
    from Olalla, WA
  6. Gremlinguy
    Gremlinguy
    Lookin real good Laidout!!
  7. Racrdad
    Racrdad
    This just keeps getting better and better. Very Nice!!!
  8. oldman2
    oldman2
    laidout,
    First I want to say this is a great build. I'm new to the site, but have watched many of the builds on this site. I follow along and look closely at the pictures, which brings me to a couple questions.
    1. Your crossmember is now tacked to the frame. Are you going to add any gussets from the member up to the inside of frame section, so it will be welded vertical also, not just on the bottom of the frame? This should keep it from trying to twist under heavy braking. You added gussets on the frame and also on your upper "A" arm mount.
    2. Your motor mount tabs are now tacked to the frame. It looks like there is only about 1/8" gap between "A" arm mount and tabs, will this leave you enough room to weld solid on both side? I saw this on your post of 11/14 pictures 7 & 8.
    I not trying to be a smart ***, and people watching please don't crucify me, just my observation, I may be getting ahead of your work. Again a great build and I look forward to your postings.
    oldman2
  9. HarborKustomSpeedShop
    from Olalla, WA
    Thanks, it never hurts to ask these kinds of questions. I apperciate it, no harm in it.
    Thanks again
    Justin
  10. oldman2
    oldman2
    Justin,
    Thanks for the quick response and anwsering my questions. I figured you had everything covered. I think Forest Gump said this, not sure "stupid is as stupid does". I'll just sit back and wait for some more amazing stuff. I'm already subscribed.
    Jim
  11. Midwest Rodder
    Midwest Rodder
    Every time I check in on this build it gets better! Your flying along and your work looks great.
  12. oldcarfan
    oldcarfan
    from missouri
    wow, looks awesome.
  13. maniac
    maniac
    I think its gonna be a shame to hide everything on the frame with the body:D.......j/k....looks GREAT !
  14. nocoastsaint
    nocoastsaint
    That is coming along nicely, and quite quickly.
  15. No_Respect
    No_Respect
    from So-Cal
    Looks good cant wait to see the *** end come together!!
  16. HarborKustomSpeedShop
    from Olalla, WA
    Thanks guys, hope to get some more done this weekend....
    Justin
  17. HarborKustomSpeedShop
    from Olalla, WA
    Well Got the housing cleaned up and the leaf spring mounts removed, and got the axle set in place. Had to switch back to my old 3-link wishbone setup since there wasnt enought room for the parrallel 4-bar. So i got both the lowers tacked in.
    Heres the pictures...
    Lower mounts (nut is welded on the back of the tab)
    Cut the gusset out of the upper wishbone because the metal i used for it was pitted. Thinking of chroming the link bars....
    Thanks
    Justin
  18. HarborKustomSpeedShop
    from Olalla, WA
    Work on the frame a little last weekend and some this weekend, got the driveline hoop crossmember made and installed,still needs some kind of gusset. Also got the upper wishbone installed, front tabs on the wishbone still need gussets. I got the body mounts tacked into place also (frames going to be sandblasted so i didnt worry about cleaning them up).
    Heres the Pictures...
    What do you think?
    Justin
  19. chaddilac
    chaddilac
    WOW... looks great!!!
  20. This is awesome. I love how very well thought out everything is. You make it look too easy.
  21. resqd37Zep
    resqd37Zep
    from Nor Cal
    Go Man Go! I really dig the 3 link wishbone set up. You've got crazy skills my man.
  22. BBYBMR
    BBYBMR
    Well i got the frame rails capped and the tie rod notches cut. only got on welded in. heres the pictures for today.
    let me know what you all think
    I think your fab skills are outstanding! Nice work.
  23. caseyscustoms
    caseyscustoms
    from st.joe, MO
    awesome work man, like looking at frame ****.
  24. Damn Laidout53, that is some very nice work!
    Keep it up!
  25. HarborKustomSpeedShop
    from Olalla, WA
    Wow thanks for all the kind words guys, Im just trying to do the best i can do.
    justin
  26. jgang
    jgang
    from hamburg ny
    this is absolutely fantastic. your fab skills are crazy. if i had 1/10 of you skills i would be lucky. keep the pics coming, they are going to help me out for sure. thanks a million
  27. HarborKustomSpeedShop
    from Olalla, WA
  28. HarborKustomSpeedShop
    from Olalla, WA
    Well Got the running Board mounted, had to modify the drivers front mount so it wouldnt hit the ground. Also started on the center section of the frame, so i will have to make a trans mount. need to get some more 2"x4" to do the otherside of the center section.
    Heres the Pictures....
    Modifing the mount...
    done....
    Center section....
    Justin
  29. Racrdad
    Racrdad
    Outstanding! Your work is well thought out and executed nicely.
  30. J.Barrett
    J.Barrett
    great job, this is getting better and better.
    subscribed..
