Projects (PROJECT) old skool twin-engine Rupp kart build...with a twist!
Discussion in 'The Hokey Ass Message Board' started by FstEdde, Jan 7, 2012.
  1. FstEdde
    FstEdde
    Thanks guys. I appreciate the encouragement.
    I've been working on the exhaust while the work on the mounts was farmed out. Here's what I started with. A couple of U-bends, a couple of flanges, and the KX60 pipes. Thanks to George for making my 1st set of flanges. However, they were too thin and I burnt thru 'em. Sorry bro. But I am going to use them for shims behind the plate.
    Wheeled off the coating and cut off the entry and exit pipes.
    Checking clearance with my back. With my jacket hanging over the back of the seat, I don't have much room.
    Started with the larger pipe right out of the motor.
    To transition from the 1.5" pipe to the expansion chamber, I clamped a chunk of heavy-wall 1.5 tube into the bench vise and used a body hammer to m***age the end of the chamber.
    The more I monkeyed with it the better it got. More or less a perfect fit after a while.
    Here's where it gets tricky. I don't have much more room off the back of the expansion chamber without hanging off the back of the kart too far.
    I really want the silencers pointing straight back. I tried a couple of bends off the back of the chamber but it stuck out too far. What about the silencers right off the chamber? Look ok?
  2. FstEdde
    FstEdde
    Thanks Rfaze. I thought about that. Probably won't be tuning while riding. Not really going to compete with this kart. However, I could always get a pair of those remote needle adjusters kart racers use.
  3. derbydad276
    derbydad276
    just found this dang this is cool
    if you were a kid in the 50's and 60's you got started 1 of 2 ways either with a kart like he is doing here
    or with a soapbox car like I play with
    if you need a axel fabbed up for this get a hold of my buddy Derek at
    www.zero-error.com he is a fab shop for karts, derby cars, bob sleds,jr dragsters,
    bar stools,and a whole bunch of other cool ****
  4. fastfish70
    fastfish70
    Beautiful job, especially on the motor mounts /chain guard. About the exhaust... I know your not worried about optimum performance and the pipes aren't exactly matched to your engines but if you want to keep the length of the stingers on the end you can run them inside the chambers with just enough of a nubbin sticking out to mount your silencers to. According to Gordon Jennings book (2stroke tuners handbook) this inverted stinger didn't have any adverse effects on performance but had the side effect of substantially reducing the noise output. We did this on a Yamaha rd350 ice racer back in the day and it worked. Also your joint between the head pipe and the chamber should be a **** weld if you can manage it, so there is no part of the header pipe sticking in the chamber and the transisition is smooth as possible. Just a couple easy tips that should help make a little more power cause we all know "Horsepower is King! Paul
  5. It's been so long since an update that I was afraid something might have happened. Welcome back.
  6. FstEdde
    FstEdde
    Thanks bro. Just using a standard Azusa Flexpruf axle. But I checked out his website...I need his help on a rotor hub issue I have.
    Thanks FF. That internal stinger idea makes sense. I have a removable silencer on the end, maybe I could insert a pipe inside from the end. I could then adjust it to the correct length. That headpipe goes into the chamber maybe an eighth of an inch. That closeup pic makes it seem big.
    Sorry Wfo. Glad to be back in the garage tho!
  7. FstEdde
    FstEdde
    Mine are 12X6.00-6 Chen Shing tube slicks. GKS doesn't list that size anymore. They have a tubeless one but I'm not sure if they're different.
    BTW-Im running staggered sizes-5" fronts and 6" rears.
  8. FstEdde
    FstEdde
    Need some help here. I bought this brake setup on eBay for the kart. It's a nice billet aluminum kit with two pistons, braided stainless line, and a cross-drilled rotor. However they were only available for 1 1/4" axles. The kits were a good deal, so I bought one thinking I could replace the hub with a 1" hub. However, they don't make 1" hubs with the 3-bolt pattern I need.
    Can anyone suggest maybe a machined spacer or shim thats 1.25 OD and 1.00 ID? I've looked all over. Lemme know!
    Thanks.
  9. Watch how many RPMs you spin them . The rod will be the weak link and will fail when over reved .. Very nice fab work I really like the mounts .
    Brian
  10. david a luciani
    david a luciani
    hi,
    even though to me you've hacked up a nice original vintage kart your build is well thought out and pretty neat.
    had to say that i'm a moderator on a vintage racing kart site.:D
    like brian said the motors you picked aren't really high rpm as the c-rod is weak.
    regardless you should be able to get er going pretty good.
    on your brake issue two ways to fix.
    one just buy a different rotor with the correct 1" diameter that's the same size rotor.
    two will be more up your alley.
    go to this url
    http://www.forum-auto.com/sport-auto/karting/sujet380714-175.htm
    this is a french auto site with a vintage kart rebuild.
    i don't read french but the pix tell the story.
    about near the bottom there's a mod he does to fit a 1" axle into a 1 1/4 set of bearings.
    basically he slotted a threaded pipe and fit it over the axle.
    the same mod should work on your brake with a little thinking.
    dave:cool:
  11. Mike Miller
    Mike Miller
    What's the one inch hub look like, can you just re drill the rotor.
  12. FstEdde
    FstEdde
    Thanks B. Let's hope they don't. If they do self-destruct, it'll be time for plan B. Twin Huskvarna concrete saw motors.
    Thanks Dave. After sandblasting I discovered the frame was stretched 3" between the steering hoop and the front axle. It's subtle, but rules out any restoration value. Actually, it gives you just a little more legroom without looking out of place.
    Checked out that French build-thanks! I see the pipe fitting but I also saw something that could work even better. He was using an Azusa Vari-hub. Remember the collar that goes over the axle?
    I have one of those somewhere! I'm gonna see if that OD would work.
  13. FstEdde
    FstEdde
    It's a 4 bolt hub. Not sure if I could re-drill the rotor...there's no meat in that area. Good idea tho.
  14. Mike Miller
    Mike Miller
    Do you have room laterally? Can you machine an adaptor from four to three?
  15. FstEdde
    FstEdde
    Yeah I do. In fact the axle has a split keyway...meaning the keyway runs halfway down the axle, then switches 180 degrees to the other side. Its at that switch where I need to place the rotor hub. An adapter would probably offset it just enough.
  16. MrModelT
    MrModelT
    This is one of the coolest builds I have seen here! ....makes me want to build one with the kids :D
    Sent from MrModelT's DROID device using the TJJ mobile app
  17. Hellfish
    Hellfish
    Great thread! I'm just starting to tear into my '60 Simplex Challenger Mark II and it has some of the same issues.
    I hope you can bring your kart out to the White Knuckle Scramble on June 29 and Sept. 14!
  18. 60galaxieJJ
    60galaxieJJ
  19. pontman
    pontman
    Your twin is cool but can it beat this quad motor laydown cart?
  20. MannyK
    MannyK
    from NYC
    This thing has a great exhaust!
  21. ss34coupe
    ss34coupe
    What a great project. Good work!
  22. FstEdde
    FstEdde
    Thanks again for the encouragement! Time to make some progress.
    Making a bracket to support the silencer. Wanna use the old tank support bracket cast into the block for support. Here's a template I made-any suggestions? Look goofy?
    Of course I`d nip off the corner of that tank support. Lemme know what you'd do.
  23. Hellfish
    Hellfish
    Silencer... as in an exhaust muffler, or intake silencer for a 2-stroke? I'd love to know what you're doing to quiet the intake.
  24. FstEdde
    FstEdde
    Exhaust silencer (muffler). Just using an open element air filter.
  25. fastfish70
    fastfish70
    Glad to see you back at it. I love this thing! Pauly
  26. What happened to this thread? Any update?
    LostBoy likes this.
  27. FstEdde
    FstEdde
    Lost interest for a while. Still have everything. Thinking of getting back to it.
  28. Sorry to hear.. I'll keep an eye on this thread so in the event you pick it back up I'll be glad to read along.
