Projects Project thread question?
Discussion in 'Traditional Hot Rods' started by Tractors & T's, Nov 28, 2020.
  1. Tractors & T's
    Tractors & T's
    from Baxter MN
    I know this will get kicked off but maybe someone can answer me before it does. I started a thread yesterday on the tow truck I'm working on and this morning I found it kicked to "Antiquated", never even knew that area existed. Did it get black balled because it doesn't have a V8 or what's the reason? Any insight is appreciated.
    dirty old man likes this.
  2. Because it's not a hotrod. It's restored.
    VANDENPLAS likes this.
  3. wraymen
    wraymen
    It’s not a traditional hot rod. That is the reason the antiquated forum was created. It fits there perfectly. Cool truck!
  4. Tractors & T's
    Tractors & T's
    from Baxter MN
  5. It’s a big truck
    And not a rod
    But it’s still fu!!ing cool !
  6. HOTRODPRIMER
    HOTRODPRIMER
    If it's not a traditional hot rod or custom, or close it gets moved to the antiquated.
    Lots of good thread get moved to that heading, I check the antiquated section often,now that you are aware of it I'll bet you will also. HRP
  7. -Brent-
    -Brent-
    No, it didn't get "blackballed". It was moved to a more appropriate section of the Jalopy Journal. That's all.
    Example, this thread will likely get moved to the question section.
    "Blackballed" usually ends up with the term "banned" beneath your screen name.:eek::D
