prop drive shaft ballancing socal?
Discussion in 'The Hokey Ass Message Board' started by carpunk, Nov 26, 2012.
  1. carpunk
    carpunk
    ordinarily i ballance it home brew style (if needed) but its on a front 4x4 shaft so i cant really test it unless its maybe on axle stands or in the snow right??
    so how much and where is best deal to get it done once i swap chop n weld my new d/s??
  2. hotroddon
    hotroddon
    I have used these guys for years;
    OC DRIVELINE
    471 INDUSTRIAL WAY
    PLACENTIA, CA 92870-6321
    (714) 993-6494
    Tell Ray that Don from Altered Engineering sent you
  3. MATACONCEPTS
    MATACONCEPTS
    <LI style="MARGIN-BOTTOM: 14px" cl***=g>
    <TABLE cl***="ts intrlu" width="100%"><TBODY><TR><TD style="WIDTH: 22px; paddding-top: 1px" vAlign=top>
    <TD style="LINE-HEIGHT: 1.24; COLOR: rgb(34,34,34)" vAlign=top>1117 West Foothill Boulevard
    Azusa
    <NOBR>(626) 334-2418</NOBR></TD></TR></TBODY></TABLE>
    1. Drive Shaft Spe******t
  4. Fogger
    Fogger
    Cooks Machine, 323-268-6571, East L.A., Wenco, 818-785-0643, Van Nuys
  5. NoPaint
    NoPaint
    How were you balancing them at home is the real question.
  6. tenlug
    tenlug
    from so cal
    X2 on OC Drive Line. Chased a vibration on my F450 with a gear vendors with a GM motor home brake mounted to the g/v. OC Drive
    Line was the only place that had the balls to chuck up the flange with the brake drum and the shaft as one piece. Saved my ****. Steve
  7. carpunk
    carpunk
    well many years ago i used to pay to have them made but since that ive made maybe 7-8 in the past and never (touch wood) had a problem or a ballance issue and driven 1000.s of miles with them but i did have one on a car with a ballance prob when i got it and i just attached a jubilee/hose clip and rotated it untill it felt the smoothest and it was fine
