Proper procedure for manually turning a 216
Discussion in 'The Hokey Ass Message Board' started by fafaniruzik, Apr 23, 2016.
  1. fafaniruzik
    fafaniruzik
    Hey all. I'm still a little green and am seeking the wisdom of those who are knowledgeable on a 216.
    Backsto is I moved my wife's great grandfather's truck to my home and am going through it to restore it to original. Everything seems pretty clean aside from caked on dirt and surface rust. But the truck has sat for at least 10 years. Wanting to make sure the engine isn't siezed.
    I have 2 questions.
    1. Ask u can see in the picture there is a slot in the crank pull and it seems like I am supposed to put a bar in there to turn the crank. Is that the proper procedure after removing the spark plugs and distributor?
    2. To manually prime the engine people say just stick a screw driver in the dist. Hole and turn w a drill. My question is flathead or phillips. And also how big?
    Any help would be appreciated.
    Thanks.
  2. paleot
    paleot
    from louisiana
    pull the plugs use marvel mystery in the cyls. rock it back and forth in high gear if the motor moves go ahead and use the starter.
    Moondog13 and slack like this.
  3. TagMan
    TagMan
    The "slot" in the crankshaft pulley is there for cranking the engine with the crank handle that originally came with the car. By the mid-30's, hand cranking wasn't used much, but the set-up was still used to make the old timers feel comfortable, in case the starter failed. You can turn the crank using those "ears" with the spark plugs in or out, but I'd make sure the coil was unhooked before cranking it, unless you are prepared to have the engine start. Hand cranking is also useful for timing the engine to get the embedded ball in the flywheel lined up to the pointer.
    You can remove the distributor and use a flat blade rod on a slow moving electric drill (CW) to prime the pump and get oil throughout the system. After you get the distributor removed, get a piece of drill rod, the same size as the distributor shaft and grind a flat to match the blade on the end of the dist. shaft.
    I'd suggest getting a copy of a Motor's Manual or the Chevy shop manual covering that engine - well worth the money it costs.
    You might also visit the Vintage Chevrolet Club of America (VCCA) website and join their chatroom, especially if you're restoring the truck to original.
    -Bob
  4. fafaniruzik
    fafaniruzik
    Thanks guys. This info definitely helps. I was planning on using marvel mystery oil but wanted to make sure the engine was free first before wasting my time. Don't worry about the coil. No battery means no problem for now.
    This was a western kansas farm truck. Bolts are coming off like magic. Haven't broke one yet.
    I'll kept you all updated on my progress. Thanks
  5. 325w
    325w
    You can easily turn from under the truck with a tool to turn the flywheel
  6. Flooganbargan
    Flooganbargan
    from Tennessee
    If you can find a 300lb gorilla, You can get him to turn the engine by hand by way of the balancer((gripping the balancer and pulling/pushing)if I remember it correctly the CR should be around 6:1) Soak the cylinders down with some sort of penetrating oil if you really do think the engine is seized. Pull the valve cover as well to make sure all valves are working as you spin the engine. if you can't spin it by hand(or if you're not a 300lb gorilla), try what paleot said what with rocking it back and forth in the highest gear.
  7. fafaniruzik
    fafaniruzik
    I am a 330 pound gorilla, so I might be able to turn by handn but am equally lazy. So I'll probably rock back and forth in high gear.
  8. fafaniruzik
    fafaniruzik
    Should I remove the distributor? If I do do I need to worry about timing?
  9. TagMan
    TagMan
    Go ahead and remove the distributor, if you want. Timing is easy on those engines. There's a small steel ball embedding in the flywheel, which can be seen through a peephole in the bell housing on the p***enger's side. Set the octane selector on the distributor to "0", crank the engine to line up the ball to the pointer in the peephole and set your points to just start opening. Get the engine running and fine adjust the timing with a timing light.
  10. blackrat40
    blackrat40
    If you would rather not to remove the distributor, and having to mess with re-timing it,
    You could tow it in high gear to circulate the oil if the engine will turn freely.
    Squirt some oil in each cylinder and leave the plugs out. Tow for ~1/8 mile.
    I would suggest you add a quart of kerosene to the oil first to try to get congealed sludge
    freed up. Drain the oil/kerosene and fill with fresh oil. Adjust the points, replace the
    spark plugs and try to start with aerosol starting spray into the carb.
    Be advised that the gas tank likely has gas turned to shellac inside as does the carb and
    should be cleaned, and fuel lines flushed out before running much.
  11. If, by saying you're "green", as in auto mechanics, I would NOT advise you to remove the distributor.
    It's not like taking a tire off, then reinstalling it.
    The reinstallation of the distributor must be accurate, dist. gear and cam gear must mesh correctly, the dist, drive must mesh correctly with the oil pump.
    Anything other than a perfect reinstallation will affect the operation (or not) of the engine.
    Your call, of course, but that's my two cents.
    slack likes this.
  12. Truck64
    Truck64
    from Ioway
    True, but how else is anyone going to learn??
    Find TDC for the #1 piston on the compression stroke. This is an important skill right there.
    Mark distributor body by scribing a line on it and engine block. This will make getting it back close to the same ignition timing.
    Pull cap off, note/mark where rotor points carefully. Pull distributor and note where rotor points as it turns when removed. If he does this carefully it will start right up no problem on reinstallation. I say jump right in and learn this stuff first hand, it's the only way it will sink in and become second nature.
  13. jcmarz
    jcmarz
    from Chino, Ca
    Why do you want to remove the distributor?? It's not like the V8 and it's not going to do anything for "pre-oiling". The 216s have a splash lubricant system which is not full pressurized. Best thing to do is buy some fogging oil, remove the plugs and spray the fogging oil inside the cylinders. Change the oil and add some Marvel Mystery oil or Rislone engine treatment and turn it by hand, using that slot on the pulley and a pry bar or pipe. If the motor is turning easy, replace the spark plugs and turn it over with the key. Expect to see smoke and if it starts, let it run for awhile and then change the oil again.
    bobg1951chevy and 270dodge like this.
  14. slack
    slack
    You may be wasting time but don't turn it. Let it soak first or you could screw up your rings.
  15. Hnstray
    Hnstray
    from Quincy, IL
    Almost sorry you asked, aren't you? :D
    Ray
  16. :confused: If not confused, we will continue to try our best. ;)
    Truck64 likes this.
  17. Don't forget these engines would run about 5 PSI oil pressure, hot, on a good day, so if you remove the valve cover to see if you have oil flow over the valves, there will only be a miserable trickle coming through. These splash oilers are fairly friendly if you goof up, but as others have said, get your hands on a workshop manual, (even a p***enger sedan book is OK, they used the same motor up to about '53), read , learn, and then once you have mastered the art of finding TDC, you can fool around with distributor, timing, etc.
  18. jcmarz
    jcmarz
    from Chino, Ca
    At idle, they may be at 5 but up and running, they go up to 25-30. They do have a oil pump.
  19. fafaniruzik
    fafaniruzik
    FREEEEEEDOMMMM!!!!!
    all, everyone's advice was good. I removed the spark plugs. used some marvel mystery oil. let it soak. over night. next day. i gave it a couple of rocks and nothing. I sprayed a little PB blaster in each port to break anything up further, waited a little bit, gave the engine block some light taps with a mallet. Then my wife decided to join me in rocking it in high gear. it broke free and spins freely.
    going to add more oil to it later to make sure its loosens up.
    After that, im going to remove the oil pan, clean out the old oil. reinstall with some fresh oil.
    rebuild the carb, and see what happens. hopefully i can get to it by this weekend. Ill let you all know if it works! thanks for the help everyone!
  20. belair
    belair
    I don't know how much you know, so if this is something you already know, forgive me. If you remove the distributor to prime the oil pump, note where the rotor is pointing. 3:00, 5:00, 9:00, etc. It MUST go back in and point the same direction,. AND you MUST NOT turn the engine while the distributor is out. The distributor is in sync (timed) to the engine and the proper position of the pistons and valves, so that the plug fires when the piston is close to the top of its travel and the engine runs. If you change the relationship of the pistons without the corresponding change to the distributor, when you put the distributor back into the engine, they (the engine and distributor) will no longer be in time. Not the end of the world by any means, but you will have to re-time the engine and distributor to each other again. To get the distributor back in, turn the oil pump shaft with a screwdriver so that as the distributor goes down and rotates, (you will have to compensate for that) it will properly engage the oil pump shaft. Whew. All very simple, basic stuff. Have fun.
  21. Be careful when removing the sump as these have a row of "squirters" which aim a jet of oil from the pump up into the bottom of the piston and cylinder. If they are mis-aligned you will get problems. From memory there is A threaded fitting which connects this squirter ***embly to the rest of the oil system.
  22. fafaniruzik
    fafaniruzik
    thanks belair,
    definitely will be making notes and marks on everything, even the oil pump slot position to make sure everything goes back together without a hitch. ill have to be sure not to bump the fan while turning the oil pump, i think im past the main hurdle of "am i screwed?" with the turning of the engine, now its just getting everything set up.
  23. Truck64
    Truck64
    from Ioway
    It's not a show stopper. Don't let anyone intimidate you. Learn how to rotate engine manually so as to find TDC on the compression stroke. Then you can remove and reinstall the distributor whenever you want, however you want and it will start right up when you do.
  24. fafaniruzik
    fafaniruzik
    Getting closer.
    Engine spins free and smoothly now.
    Drained old oil. Was black but no sludge. And put new oil.
    Got to rebuild carburetor. File the points and got a new fuel pump on order.
    Couple weekends and this guy should fire up hopefully. [emoji91]
    Half the job is s****ing all the old dirt off.
    If everything pans out. I'm off to the brakes which will cost an arm and a leg since the drums are 8 lug and obsolete.
  25. fafaniruzik
    fafaniruzik
    Update.
    Hooked everything up. Engine didn't even think twice about starting. Not bad after sitting 28 years
    Sent from my SM-G930V using H.A.M.B. mobile app
    Truck64 and clunker like this.
