Proportioning valve plumbing?
Discussion in 'The Hokey Ass Message Board' started by 4woody, Jan 2, 2014.
  1. 4woody
    4woody
    With this style valve (1989 S-10 disc/drum), which ports go to the front discs, which to the drums??
  2. 4woody
    4woody
    Technical difficulties..here's that pic
  3. 53sled
    53sled
    from KCMO
    I had this setup on mine after I put the jag front end (big calipers).
    Hope this helps.
  4. 4woody
    4woody
    53 sled- thanks for posting.
    That's the same one I used to have that was leaking.
    I'm still not sure if the ports on the left in your pic (front) correspond to the ports on the left in my pic...or is it backwards of that??
  5. 4woody
    4woody
    Anybody?
    TTT
  6. ohiohotrods
    ohiohotrods
    on a disk drum setup this is a must for piss poor brakes-wrong pedal ratios- rear brakes that don't work at all ,,,etc.
  7. brokenspoke
    brokenspoke
    whats your suggestion?
  8. drptop70ss
    drptop70ss
    from NY
    If you cant find out by the end of the day I will check tonight, I have the same unit on a 95 S10 parts truck. There is actually another valve plumbed inline with that valve on my truck, I think it is a poor mans anti lock setup for the rear brakes but I have not reseached it yet.
  9. 4woody
    4woody
    Still looking for an answer on this.
    BTW that other valve is abs related, but the prop valve is supposed to do it's job fine without it.
    To the other poster who commented about it not being the right valve: I chose this valve because the vehicle it came off- late 80's, early '90s S-10 Blazer- has similar brakes (GM metric front discs, 10" drum rears) and similar size, weight, and m***ing to the '50 Plymouth wagon I'm putting it on.
    I just forgot to mark the ports when I took it off at the junkyard.:(
  10. seb fontana
    seb fontana
    from ct
    Post #2 doesn't look like a proportioning valve [brake switch manifold] but #3 does..I'd get a stand alone valve and mount under floor with stem through floor so you can reach it from in the drivers seat..
  11. drptop70ss
    drptop70ss
    from NY
    Looking at your picture the left side top is the rear brake input, left side bottom is rear brake outlet. Rear brake lines in and out are 1/4", front brake in and out are 3/16". Looking in at the port holes the larger size for the rear brake lines should be easy to see.
  12. 4woody
    4woody
    Thanks drptop. That is what I thought. It is in and plumbed, so I couldn't look inside, but the brakes don't seem quite right and I had one of those "Did I do that right?" moments.
