Technical Protecting short block
Discussion in 'The Hokey Ass Message Board' started by greg025, Apr 28, 2018.
  1. greg025
    greg025
    I’m planning to change the heads on my 350. I do my work in the driveway and I’m concerned about anything that might come up and prevent me from getting it done in a day. If not it might be a few days before I can get back to it or I might need an unexpected part... I ***ume covering the intake valley and cylinders with rags will provide some protection. Is there anything else I should be doing? How long would I be safe to leave it like that?
    Thanks
  2. Cover it with a tarp and bungee cord it down. Wouldn't hurt to spray it with fogging oil first.
  3. bobss396
    bobss396
    I used to spray it with WD40 and put a piece of cardboard over it.
  4. 56don
    56don
    Run strips of duck tape across the cylinders.
  5. greg025
    greg025
    I was thinking about wd40 or a light coat of oil and will probably do some combination of the other suggestions if needed. I have an extra short block that had been sitting in the seller’s garage. It had the cylinders lubricated and covered with foil glued to some old head gaskets. That seems to have worked well.
  6. 1 do not leave any open holes.
    2 do not let it get wet
    3 plan your exit strategy before you start
    slowmotion and Just Gary like this.
  7. Johnboy34
    Johnboy34
    from Seattle,Wa
    Shop vac out any water in the water jacket, cylinders and such. Then you can seal it up with seran wrap, it sticks good.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  8. Truck64
    Truck64
    from Ioway
    I like WD40 for some things but I haven't found that it provides particularly long lasting corrosion protection. It's better than nothing but there are better products for this purpose. We all know how a couple days can turn into a couple months.
  9. greg025
    greg025
    Yeah with a 3 year old, a pregnant wife and the weather how it’s been this year I really don’t want to have to rush through it. I think I’ve heard before that wd 40 wasn’t the best when storing an engine. Saran wrap sounds like a great idea also. I hope I responded to everything I wanted to. Can’t see previous posts while typing.
  10. slowmotion
    slowmotion
    Fog it. tape it, tarp it. You can get those 4'X6' tarps at HF for damn near free.
