Protecting you engine from ethanol
Discussion in 'The Hokey Ass Message Board' started by Dog Dish Deluxe, Feb 8, 2012.
  1. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    Fuel issues existed in the 20s,30s 40s ect.I've been dealing with bad gas issues since I mowed lawns with a push mower at age 14 I'm 49 now.Early engines were low compression ratio because of piss poor fuel.Adapt,or find a different hobby.I wish that we had only 100% alcohol for fuel in the United States.That would make everyone who wanted to drive,very innovative,we could also build engines with obnoxious compression and/or boost levels,extremes of ignition advance, motoroil would stay cleaner longer.All this **** with gas tanks fuel lines fuel pumps and carbs can and could be overcome,as well as the cold start ect.
  2. Dog Dish Deluxe
    Dog Dish Deluxe
    from MO.
    I finally put some 02 sensors on my car and hooked up the DVOM. Havent had a chance to go drive around town yet because I have to do "Domestic" stuff the rest of the day, but Idling around the driveway it looks like im in the .6-.7 range on the driver side and the .8-.9 range on the p*** side. Not as bad as it could be since thats just and "eyeballed" idle mixture. The real readings and tuning will come when I get a chance to drive around though. Possible a bunch of jet, accelerator pump (Holley) and timing adjustments in store.
  3. Engine man
    Engine man
    from Wisconsin
    That's strange because Briggs and Stratton warns against using it. Stihl warns against using it. Te***seh warns against using it.
  4. Fenders
    Fenders
    Maybe not:
    "As a rule, E10 fuel is compatible with all STIHL chain saws and power tools, as well as VIKING gardening tools with engines by Briggs & Stratton, Kawasaki and Kohler. A carburetor adjustment may be required ...."
    http://www.stihl.com/e10-gasohol-ethanolgasoline-fuel-mixture.aspx
    I didn't check the other makes... I've been using E10 here in M***. in my rod that has an old Holley 4160 on it for a year so far with no ill effects.
  5. couvy
    couvy
    Those of us who work in the petroleum industry would like to add 10% gasoline to all corn products!! How would that make your cream style corn go down
    Truck64 likes this.
  6. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    Kinda lippy for an fng ain't ya?Stick to the issue at hand,nobody is going to add 10% petro chemical **** to corn for consumption.This ethanol is bad **** is really getting old.Find a new horse that ain't dead, to beat.
  7. Dog Dish Deluxe
    Dog Dish Deluxe
    from MO.
    Chill out guys, it's not THAT bad. Sheesh.
  8. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    That is good info,thank you Sir.
  9. gearheadruss
    gearheadruss
    from Seattle
    a local radio show here in the Seattle area that helps listeners call in with their car problems has on severl occasions mentioned that here in Washington state we will be going from 10 to 15 percent. They claim it will run ok on the newer OBD2 since their computers can adjust for the ****py fuel but the cars with OBD1 or older will suffer. And we will be getting worse mileage and that's the biggest reason our government loves it. We drive the same distance and buy more gas and they get more tax dollars.
    The mayor of Seattle drive a bike to work.
  10. Yes ,all problems can be overcome and Im sure that some of the real smart guys here on the HAMB are just the ones to do it.But it is a big problem to certain people who cannot overcome the issues... the posers who just want to gas and go and the regular guy who tries to fill his boat and ruins his fuel system.
    Some people want to file a cl*** action law suit against Volvo Penta because they painted the inside of their fuel cells instead of plating them...at $700 each time to replace one it gets costly.So who is to blame?
  11. Fortunateson
    Fortunateson
    I'm quite interested in the chemistry that makes a water molecule smaller. As I understand chemistry the formula for water is 2 parts Hydrogen atoms and one part Oxygen atom. Are you saying that formulation can be changed? This reminds me of the "Instant Water" product I saw which you only had to add water to. LOL
  12. Dr. Frankensickle
    Dr. Frankensickle
    from Kansas
    Working at jiffylube doesn't really qualify as working in the petroleum industry
