proud or ashamed ?
Discussion in 'The Hokey Ass Message Board' started by black 62, May 21, 2013.
  1. black 62
    black 62
    from arkansas
    i was trying to get my 55 parts car to roll and of course the brakes were stuck---i started the long process of prying and beating---then i thought , can my beloved die grinder solve this delima ? i went above the pin where the retainer springs for the brake shoes attach and cut a slot about 3 inches wide all the way across the top of the brake drum , knocked it out with a hammer, reached in and removed the springs and the retainer ---ground the heads off the brake nails, removed the spindle nut and slipped the drum off ,removed the shoes and reinstalled the hub---the whole thing took less than 5 minutes on the second one ---lots of rust from sitting on the ground so the drums were toast ---seems destuctive but it sure did work...
  2. henryj1951
    henryj1951
    from USA
    or you could a released the parking/emergency brake handle.....lol....j/k
    :cool:
    i'm proud of ya:D
  3. fsae0607
    fsae0607
    Who cares it worked!
    Hey at least you didn't do what I did... On my '61 when I tackled the front brakes I ***umed that the drums come off like newer cars and I beat the **** out of the drums with a sledge, torched the hub, pryed and drove to each auto parts store looking for a drum puller, just to open the shop manual and realize that the drums and hubs are riveted together and come off as an ***embly via the castle nut.
    Waste of half a day... :mad::eek:
  4. Saxman
    Saxman
    Oh man, I did that SAME thing once!!:eek:
  5. Saxon
    Saxon
    from MN
    There are two systems of procedure.
    The think,think,work or work,work,think procedure.
    Both have their limitations. With one way you might get less work done, but the work will be done faster and probably with less difficulty and mistakes. The other may get more things done, but makes you wish you hadn't have done it that way. :]
  6. bustingear
    bustingear
    ingenuity at work
  7. manyolcars
    manyolcars
    you ruined the brake drums?
  8. Snot Rocket
    Snot Rocket
    Or have to do it all over again.
    Did you consider grinding off the nail heads, unscrewing the adjuster and unbolting the wheel cylinder? That would have had about the same result without ruining the backing plate. Some backing plates even have a screw on pivot at the bottom.
  9. fsae0607
    fsae0607
    Haha cl***ic case of not RTFM'ing!
  10. black 62
    black 62
    from arkansas
    did not harm the backing plates only the drums ---too mch rust for adjuster function...
  11. 65ssnova
    65ssnova
    from Tulsa OK
    I guess that works...
  12. el Scotto
    el Scotto
    from Tracy, CA
    I hate that!! :mad:
  13. Mr48chev
    Well if the drums were shot anyhow it's no loss and time and headaches saved.
  14. oakmckinley
    oakmckinley
    You're not alone. Been there, wasted 2 days soaking and beating with a 3lb sledge.
    Funny how easy they came off after I removed the nut. :eek:
  15. fsae0607
    fsae0607
    Didn't you feel like a dumb***? Once my dad found out what I did he laughed at me and to this day he still clowns me about it. :p
