PS pump pulley removal
Discussion in 'The Hokey Ass Message Board' started by gatz, May 9, 2013.
  1. gatz
    gatz
    although the pump in question is not really "HAMB" , the application is (or will be)
    I need to change this over to a V-belt.
    How the heck does the pulley come off this '94 Cavalier pump ?
    The pump shaft had a partial threaded hole that I cleaned up with a 3/8-24 tap (wasn't metric) without too much difficulty, but that doesn't seem to have a bearing on how the pulley is attached.
    At first I thought I could see something like an internal hex or a Star recess in the shaft; but after digging around in there, found that there wasn't.
    The "hub" in front has a neck or reduced diameter that looks like it could be used with a puller. (?) However, there wasn't any bolt in that partially threaded hole to hold it on.
    Is this just a press-fit? Is there a special removal tool?
  2. It takes a specific puller . Most of your parts houses keep one available for rental ... ask em.
  3. Rocky
    Rocky
    Classified Editor
    Yup...your napa dealer has a "power steering pulley puller" for a fair price. I use mine a few times every year. The threaded hole is to use when installing the new pulley and also using that puller to install the new pulley.
  4. 56sedandelivery
    56sedandelivery
    The threaded hole is used with a bolt, nut, and washer to INSTALL the pulley. I have a rebuilt pump sitting here for my truck that I've got to install. The instructions for it say, "use a suitable puller", to remove the pulley, and they include a bolt, nut, and washer that's used to install the pulley. There is a recessed ring towards the end of the pulley boss that the puller jaws grip onto. Butch/56sedandelivery.
  5. evintho
    evintho
    The infamous Harbor Freight power steering pump pulley puller. Yeah, I'm aware it's HF basura but how many times will you actually use it, in your life.........5? For $20 you can't beat having it in your toolbox for when the need arises! And, it works! I've used mine 3 times. I'll either get 2 more uses outta it or I'll die.........whichever comes first!
    http://www.harborfreight.com/pulley-remover-and-installer-set-40749.html
  6. gatz
    gatz
    thanks for all the info/suggestions
    got a 20% off HF coupon, so that may not be too bad a deal
    and after one or two uses, it'll probably end up on "the estate sale"
  7. gatz
    gatz
    Got the HB pulley puller kit last week.
    Made it very easy to get the pulley off. Served the purpose.
    Now, anyone know if or what V-belt pulley would go onto this '94 Cav (GM) pump in place of the poly-v ?
    Would an earlier year V-belt type fit it? The shaft is 0.750
  8. Ole don
    Ole don
    After thinking, fighting, and arguing with any part of a car for an hour, a day, or a week, remember this. The guy in the ***embly plant put it together in less than 30 seconds.
  9. I think JET performance carries one.
  10. dave lewis
    dave lewis
    from Nampa ID
    oval track power steering pumps are based off the cavalier / s10 pump..
    speedway sells v belt pulley for them..
    Dave
  11. Dorman has few for 0.750 shaft and V belt
  12. gatz
    gatz
    thanks guys...will check them out.
    gatz
  13. mgtstumpy
    mgtstumpy
  14. d2_willys
    d2_willys
    from Kansas
    Got me one of the PSPPP's from an auto supply house back in the early 90's. $60 for the puller and installer together, but man did they do the job!
  15. Mr48chev
  16. S_Mazza
    S_Mazza
    That just makes it more depressing. Especially when some of your difficulties are related to decisions made for cost or ease of manufacturing.
  17. gatz
    gatz
    Stopped at Speedway, their V-pulley has a 0.660 inside diameter. Thought about buying one and boring it out, but decided not to for now. May end up getting it if all other sources come up empty.
    Live-chatted with a rep from Dorman this evening They don't have a V-belt pulley.....only the poly-v (serpentine) stock replacement; their p/n RB300131
    Have yet to try Cl***ic & Alan Grove.
    I did pick up a seal kit for the pump at NAPA. was less than $13.
    If you wanted only the shaft seal ...........it was $17.
  18. gimpyshotrods
    gimpyshotrods
  19. gimpyshotrods
    gimpyshotrods
  20. leonhkbx
    leonhkbx
    from new york
    Most of your parts houses keep one available for rental[​IMG]
  21. gatz
    gatz
    thanks for the info, gimpy.........I'll order one of those 300-122 pulleys from Summit.
    I don't quite understand why that guy told me they didn't have a V-belt one.
    Coulda been that when I clicked on the live-chat ****on, I got connected with Auto Parts Warehouse; evidently not Dorman's
    Or, that "Bruce" the chat guy mighta been from India....who knows
  22. gimpyshotrods
    gimpyshotrods
    All of the time, I get "that doesn't exist", "nobody makes that", and "we don't carry that", in regards to what I am holding in my hand, often with the packaging, from said supplier, present and intact.
