1952-59 Ford Puff pufff
Discussion in 'Off Topic Hot Rods & Customs' started by greaser 35, Apr 8, 2024.
  1. greaser 35
    greaser 35
    from FRANCE
    I have my 1954 Ford 6 cylinders that ratatouille while driving slowly it as misfires and farts when decelerating, I checked my spark plugs OK ! what could this be coming from??
  2. greaser 35
    greaser 35
    from FRANCE
    It has holes at low speed!!
  3. greaser 35
    greaser 35
    from FRANCE
    I have gas !!!
  4. 56longroof
    56longroof
    Check your timing and make sure your carb isn't overly rich. What carb do you have? Could be a bad power valve or needle and seat not closing off properly.
  5. greaser 35
    greaser 35
    from FRANCE
    1 BBL HOLLEY ! A simple carb on my 6 cyl!
  6. greaser 35
    greaser 35
    from FRANCE
    I've had this problem since I ran out of gas! Maybe some **** in the carb??
    abe lugo likes this.
  7. Dos Cincos
    Dos Cincos
    Could be clogged fuel filter or carb. Most likely ****ed up some **** out of the tank when it ran dry
  8. shortshift
    shortshift
    my old 6 cyl had a hole rotted through the intake into the exhaust. started poorly but ran. could not see the hole til i took carb off
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    Possible bad condenser, most are now offshore made and have been causing issues like that and more on several Ford Forums, in most cases putting the original OEM Ford condenser back in will cure the problem. NEVER toss an original !
  10. greaser 35
    greaser 35
    from FRANCE
    This is a original condenser !!! I just think it's **** in the carb, I'm going to clean it, put a fuel filter in and I'll see!
  11. greaser 35
    greaser 35
    from FRANCE
    It's my fuel pump !! she's dead !!!!:(
    Rui likes this.
  12. greaser 35
    greaser 35
    from FRANCE
    I changed my fuel pump and it works well with the new electric fuel pump! Last question! as soon as I put my original air filter it grazes (it to grates) and when I remove it it goes better! What can it come from?
  13. greaser 35
    greaser 35
    from FRANCE
    The whole fuel system is clean, there is a new fuel filter and the carburetor is also clean !
  14. greaser 35
    greaser 35
    from FRANCE
    I think I found the problem! the electric fuel pump is too high compared to the tank! The gasoline does not stay in the fuel filter when I turn off the engine and I have a slight break in the fuel hose! It could come from there!
    Rui and down-the-road like this.
  15. greaser 35
    greaser 35
    from FRANCE
    I found another problem on the Ford! the spark plug cables, because it was running on 5 cylinders instead of 6 cylinders , I put my old ones back and it goes round, only it backfired to deceleration! What can that come from? Big shot in the exhaust!
  16. nosford
    nosford
    Usually backfire in the exhaust is caused by unburned fuel being ignited in the hot exhaust instead of in the cylinder. When we were kids we used to turn the key off on deceleration then turn the key on and get a huge boom when the fuel that was now in the exhaust (from the turning engine without ignition) ignited. Was fun till you realized the muffler was now exploded from the blast. So, anything that momentarily interrupts the ignition will dump raw fuel into the exhaust and could cause this. Also, if you are running a straight pipe or even gl*** packs you will hear some popping and noise from the exhaust normally. Mark
