Hot Rods Puffen blue smoke
Discussion in 'The Hokey Ass Message Board' started by Bonehead II, Aug 31, 2023.
  1. Bonehead II
    Bonehead II
    I replaced the gasket under my carbs, between the blower case and the carbs base, because it was leaking fuel.
    I also use Permatex High Tack along with a new gasket, Now it puffs blue, but does not smell like oil, Do you think its from the permatex high tack ? And do you think it will burn off ?
    Thanks for your time.
  2. HOTRODPRIMER
    HOTRODPRIMER
    Is the smoke coming from the exhaust? HRP
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Carb gaskets get installed dry. I hope that stuff hasn’t messed with your rotor seals.
  4. Bonehead II
    Bonehead II
    Yes
  5. squirrel
    I think even if you poured a little of that sealer down into the blower, it probably would cause symptoms other than blue smoke.
    Maybe it's been puffing at start up for a while, and you never noticed it before? or maybe there's some other issue that caused it to get wet fuel there, which is somehow causing the oil smoke?
    427 sleeper and chryslerfan55 like this.
