Technical Pull head on SBC without removing intake manifold?
Discussion in 'Traditional Hot Rods' started by Greasyman, Jan 31, 2021.
  1. LOU WELLS
    LOU WELLS
    from IDAHO
    A Simple Question Turned Into Engineering Magic And There Is A Chance The Intake On A SBC Will Leak If You Remove It Or Not.....Proceed...
    lippy likes this.
  2. Budget36
    Budget36
    Pics of your combustion chambers and piston tops, then we can see if any of them are cleaner than the rest.
    FWIW, Any bad head gasket I’ve had has been easy to spot.
  3. Ebbsspeed
    Ebbsspeed
    That was the first thing that popped into my head when it was suggested 100 posts ago, but I chose to refrain from making a comment because this has turned into a circus. All cylinders on one side at 150, and the other side all at 120?
    Different heads or pistons side to side is my guess. It's a 1959 block, so anything is possible.
    Deuces likes this.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    One thing that is sadly evident here is folks p***ing judgement on something that not only have most likely never tried , but probably never thought to try , very closed minded . This would be out of character for the old time hotrodders you claim to emulate , but not at all unexpected from folks who. don't want any improvements to their cars that have been developed in the last 56 years . ( except engines , transmissions , brakes , tires , ignition systems & on & on ) Its really very entertaining .....:rolleyes:
    TA DAD likes this.
