Technical Pulley alignment question: 59AB into '39 Ford
Discussion in 'Traditional Hot Rods' started by BarnFind39, May 20, 2023.
  1. BarnFind39
    BarnFind39
    I'm slightly confused on my options here. I'd like to keep it original looking using a generator driven fan and I'm wondering if the belt will line up. I've been reading a bunch of posts and it sounds like it will, but I would like to know for sure, so I know which generator to take to get converted to 12V. Thanks
  2. FritzJr
    FritzJr
    Your '39 Deluxe originally had a crankshaft mounted fan. If you want to have a generator mounted fan, you will need a two brush generator from a '39 Standard. They can be converted to 12 volt. The pulley will line up with the other pulleys on the 59AB engine.
    leon bee likes this.
  3. BarnFind39
    BarnFind39
    That’s excellent, I’m glad I was mistaken about what should’ve been on there. Thanks!
  4. dwollam
    dwollam
    Pretty sure a '39 standard generator and fan will be too high in a DeLuxe.
    Dave
  5. alchemy
    alchemy
    If you have the space for a crank fan, as a 39 Deluxe should, I can’t think of any reason to do something different. Super simple.
  6. flatjack
    flatjack
    As noted, a generator mounted fan will not work in a DeLuxe
