Pulling motor in my F100
Discussion in 'The Hokey Ass Message Board' started by Cleetus, Oct 15, 2013.
  1. Cleetus
    Cleetus
    from Austin
    Im pulling the motor and transmission out of my 65 F100 and I am wondering if someone has any tips. Should i pull it all out at once in one piece or should I pull them apart? Thanks
    Also does anybody recommend an engine builder near Austin?
  2. not real familiar with the F100 , but i always try to pull the motor/transmission together
  3. HOTRODPRIMER
    HOTRODPRIMER
    I pulled mine as a unit the engine & transmission together. HRP
  4. hendo0601
    hendo0601
    from Tacoma, WA
    Its way easier and more time efficient to pull them as a unit rather than going through the h***le of unbolting the bellhousing/torque converter etc while it is all in the car. With a good cherry picker and load tilter you should be able to yank it out in no time.
  5. chaddilac
    chaddilac
    Make sure your picker can go high enough to get the tail shaft over the core support, you can always drop the truck down after you get the motor un hooked and attached to the picker. Take the wheels off to get it really low! :)
  6. belair
    belair
    Protect or remove the radiator.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Definitely remover the radiator and if you got any help go ahead and remove the hood. HRP
  8. Cleetus
    Cleetus
    from Austin
    Anybody in Austin want to make a little extra money helping me out with my truck? Looking for some help from someone who has experience with electric, motor, trans and fabrication...ie lowering, ch***is and body mods...
  9. tb33anda3rd
    tb33anda3rd
    or better yet, pull the whole nose off.
