P21 PULLMAX Style STEP DIES CORNER CRISPER's & PROFILE DIES .750-3/4-19mm SHANK (P-5 P-6 P21 P200) ALSO FITS P-5 & P-6 IF THEY ARE CUT DOWN $175 FREE SHIPPING in U.S. MILD STEEL POLISHED Made in the U.S.A. Planishing Hammer Rams Head Die Adaptor - CP style Adaptor to run CP style lower dies (approx. 13/16ths base) in Rams Head planishing hammer. Positions most CP style die faces at the same working height as the original floating Rams Head dies. FREE SHIPPING in U.S. $95 Buy adaptor only. Dies & planishing hammer not included. Machined in Los Angeles Made in the U.S.A. 12 Volt to 6 Volt reducer for gas gauge etc. Great way to use vintage/original gauges when switching Easy to install & reliable!!! Includes voltage reducer unit, mounting eyelet, and 2 butt connectors. FREE SHIPPING in U.S.! $15.99 INSTRUCTIONS 1.) Determine which wire to install unit on. *Make sure unit is installed in “power” side of gauge, NOT “sender” side. 2.) Disconnect the battery. 3.) Determine suitable mounting location. DO NOT LET HANG. (a mounting eyelet is provided on unit) 4.) Cut & splice unit into gauge circuit: *RED wire connects to the “power” or “keyed power” wire coming from the ignition switch or battery. *GREEN wire goes to the gauge. *BLACK wire needs to be securely fastened to a clean, bare metal ground. 5.) Re-connect the battery and check for proper operation. CAUTION: *Use ONLY with NEGATIVE ground wiring systems. *One voltage reducer per electrical gauge. *Be sure to disconnect the positive cable from the battery to avoid electrical shock! *DO NOT use with amp meters or motors (i.e. heater blower motors, windshield wipers) or with other high current draw applications PULLMAX Collet Wrench Unique design- Works with all types of unusual/oversized Pullmax dies and low clearance situations. Positively "locks" into collet groove, to eliminate slipping and "rounding off" of collet edges. Fits P21, P6 & may fit other models as well. If you have a different model, let us know and if it doesn't fit, you have 14 days to return it. $44.99 FREE SHIPPING in U.S. Made in the U.S.A. Email for more info.
