Pulls hard left under accel
Discussion in 'The Hokey Ass Message Board' started by slinginrods, Nov 16, 2012.
  1. slinginrods
    slinginrods
    from florida
    It has a half rack or maval steering rack installed,should not be affected by bump steer.
  2. Pete Eastwood
    Pete Eastwood
    from california
    You'll have to explain to me how that type of steering is not affected by bump steer.
    All types of steerings can & will be affected by bump steer if things are not mounted correctly ( it's all geometry ! )
  3. slammed
    slammed
    Slinginrods, stop and listen to Mr. Eastwood.
  4. DICK SPADARO
    DICK SPADARO
    Bunch of posts, bunch of ideas but no base line. Issues like this really need a picture to convey how you have built the vehicle and then closeups of some areas in question.
    After reading some of the poster response one glaring item stuck out, that being the poster relocated the coil over load and then readjusted one of the upper control rods for better fitment. Readjusting a control rod would be an indication that something is out of alignment or not correctly aligned from the beginning.
    If you did that something is wrong from the start. Most case I have addressed with drive steer issues can be traced back to failure to square the front and rear axles to each other and the vehicle.
    My question did you and how did you square the axles to the ch***is? Without doing this one axle points one direction the other points in another or severely worse, as acceleration and speed increases the tracking dynamics become more magnified.
    By squaring your axles you know where your base is and then if there is an issue you can go from that point to remedy the problem.
    Now your posts indicate that this happens under severe acceleration and during left turns. This leads me to focus on the ch***is for hints of design or ***embly defects. Left turn issues indicate that the ch***is was inducing steer as the ch***is rolled right. (Left side up, right side down) My question, which way do you correct by turning the steering wheel further to the left or by back steering and turning to the right?
    I am interested in the location of this half rack steering box at the present time as a potential source of the steer problem since it is located on the left rail and the left rail is moving up during acceleration and up during right roll. This would have an effect on the p***enger side steer arm hook up.
    Post back what you checked out and see if you can post some pictures so its not a guessing game.
  5. Jkustom
    Jkustom
    x2. If you don't know who he is, just take our word for it. :)
  6. slinginrods
    slinginrods
    from florida
    I know who he is.again no argument here ,the car only has a few hundred miles on it.what I found was the pre load in the four link was off.i don't have any problems with bump steer on this vehicle,and I know what bump steer is.i will try to get som pics of the steering to quell any worries that the ch***is was built incorrectly.again I thank you for your input.
  7. slinginrods
    slinginrods
    from florida
    pics
  8. slinginrods
    slinginrods
    from florida
    more
  9. slinginrods
    slinginrods
    from florida
    my pics of the ch***is fabrication were lost on a bad comp.but rest ***ured the frame was built square and true on a fixture by a reputable fabrication shop.its not uncommon for the rear 4 bars to need some tweeking.i posted before i really dug in to look at the problem.i had ***umed the bars were adjusted correctly.we all know what ***ume means lol.
  10. slinginrods
    slinginrods
    from florida
  11. slinginrods
    slinginrods
    from florida
  12. Johnny Wishbone
    Johnny Wishbone
    Sounds like you've got some stagger in it. Run a tape around the tires and make sire the cir***ference is the same on both tires. Right tire being slightly larger will make it go left under hard acceleration.
  13. Pete Eastwood
    Pete Eastwood
    from california
    In your photos, the car appears to have shackles on both sides. You said it has a dead perch, am I missing something? or was one installed after the photos were taken ?
  14. Pete Eastwood
    Pete Eastwood
    from california
  15. n.z.rodder
    n.z.rodder
    Have you taken the car out since re-setting the rear? R&P steering on a solid axle is illegal here in NZ because of the problems it causes. Even if the tie rod is level, under hard acceleration it WILL pull to one side because of the arc it goes through, a shorter tie rod is worse.
    Scotty
  16. Scumdog
    Scumdog
    Hmm, on reading his first post it does not sound like any form of bump-steer, he would have found general twitchiness all the time if it was bump-steer - and with that set-up it would want to steer to the right as the weight came off the front suspension and the shorter arc of the rack 'pulled' on the left-hand steering arm.
    My 2-cents worth given free!;)
  17. n.z.rodder
    n.z.rodder
    Correct, If the tie rod rises toward the wheel it would push, which is what I should have written in my post. The photo's don't show that side of the set-up.
    Scotty
  18. DICK SPADARO
    DICK SPADARO
    Slingnrods, thanks for the pictures, nice car, that helps describe what you are working on. I have been following responses and without actually measuring the axle position I still feel that you are like a dog chasing it's tail. I realize that the ch***is has been jig welded but usually during ***embly everything is just nut and bolted together and ***embled but never actually checked. Counting exposed threads does not account for accuracy. When you have indicated that you have adjusted the shock pre load that really doesn't do anything in regard to alignment issues and back to adjusting just one bar to remove bind indicated there is something amiss during ***embly. Back again to sqauring your ch***is I posted on another similar issue today, if you are unsure of the method of checking your vehicles axle sqaure there is a post on the HAMB done a few years ago by Brian Angus, do a search locate this post and it will outline the quick way of determining your axle position. I dont think this has anything to do with dead perches, panard rods, tire size or loads.
  19. grm61
    grm61
    from Washington
    What kind of Possie or locker is in the rear diff??
    Check rear tire pressure.
    Light em up, make sure BOTH rear tires are getting power if you have a lsd or locker.
    IF it has a locker, you could have a broken axle and not know it if it is a non C clip axle.
  20. slinginrods
    slinginrods
    from florida
    That is some useful info.this is the first car I've used this on.could this be due to the rise of the front end? Kinda makes sense since there is only one tie rod and not two like on a standard rack and pinion.
  21. slinginrods
    slinginrods
    from florida
    I know that on cross steer there is place.for these.I have never experienced the wander that can come from the tie rod causing the axle to shift. Tire size will most definitely amplify this.larger the tire width the more load induced.I run a narrow 165 80 15 tire on a4 inch wheel.it is really relative to load on the perch.did henry use those on factory cross steer?im sorry for previous post.there is No deadman on this car.past car had one.last two have not, I tried it out didn't seem to matter.
  22. slinginrods
    slinginrods
    from florida
    Will look this up and recheck everything.thanks
  23. Pete Eastwood
    Pete Eastwood
    from california
    A 1902 Packard has a transverse spring, a 4-bar, cross steering & a panhard bar !
    1930's driving demands were much different that today's, almost no high speed driving or cornering.
    Ford went to cross steer in 1935. By 1940 they added a front anti-roll bar, which has attachment hardware that also helps control side to side movement (like a pahard does). By 1947 (or '48) Ford equipped all cars with a panhard bar (front and back).
    On todays cars ,with a transverse spring & cross steering of any type,(vega, half rack, or whatever) a panhard bar or dead perch is critical ! ! (panhard bar being best).
    PUT A PANHARD BAR ON IT !
    OK I'm Done . . . . . . . .
    Good Luck !
    Pete Eastwood
  24. gassersteve
    gassersteve
    Move the engine to the right. The relocation of the weight will make your car go straight
  25. n.z.rodder
    n.z.rodder
    Actually two tie rods are worse because the wheels then go in opposite directions (toe in and toe out) as the front articulates through it's arcs, rather than both in one direction as with your cross steer system.
    Have you driven the car after re-setting the rear?
    Scotty
  26. slinginrods
    slinginrods
    from florida
    great info,that's why I asked.interesting on the Packard .my friend just built a 40 and he used a sway bar on it too.also used power steering.split wishbone,cross steer with later box .drives great.you been building them longer than me I'll look into a pan hard .thanks again.
  27. slinginrods
    slinginrods
    from florida
    Most modern cars and trucks use rack steering today,everything that comes from the factory of the brands I wrench on at the dealership have racks.i was referring to a later a arm/ strut type suspension.ive never seen a rack on a solid front axle ,although I'm sure there out there.the rack can move with the control arms and have zero bump steer ,if they are set up right.i will be driving tomorrow ,got home late.
  28. Scumdog
    Scumdog
    The only way a r&p steering box will work 100% with a solid axle is if it's mounted to the axle - and that would require a telescopic/flexible steering column..
    T-bucket style with the r&p sideways and pushing/pulling on the dirvers side steering arm on the back of the spindle is also pretty good.
    But the set-up you have with half a rack pulling/pushing on the steering rem is a big :confused: as to it's integrity of keeping track of the suspension movement without causing some sort of steering action as the suspension rises and falls (whether by going over a bump on the road or the front rising under acceleration).
    The end of the r&p will be moving htrough a diffeent arc to the solid axle, make no mistake about that.
    Again my 2-cents worth posted free.
    (Unhook the r&p arm from the back of the spindle, move theend of it (the r&p part) up and down and see what sort of arc it moves through - and then check how your axle behaves as it goes through the suspension travel, it shouldn't be moving through any sort of side-to-side arc)
  29. n.z.rodder
    n.z.rodder
    Grab someone to video it from the front and rear, will be interesting to see.
    Scotty
  30. 32ratsass
    32ratsass
    I've read the entire thread and fully agree with this post. Doesn't sound at all like a front end problem, based on your description of what it's doing. The only front end issue that I can see is the need for a panhard bar, as Pete Eastwood stated. It needs one, but I don't believe this is what is causing this particular problem.
