Technical Punch marks in Double Hump exh seats??
Discussion in 'The Hokey Ass Message Board' started by Baging, Aug 21, 2016.
  1. Larry T
    Larry T
    Getting back to the original post -
    Stakes are part of the valve seat replacement. The heads are used and the seats haven't fallen out, so apparently they are ok.
    Almost everything else here is good info, but not what the original poster asked.
    Thanks to squirrel for getting things headed straight.
    Carry on! :D
    Baging likes this.
  2. henryj1951
    henryj1951
    from USA
    YA STAY ON POINT or GTFO...
    you you embellishers go home tist tist
    stake them seats its insurance to make sure they HOLD
  3. Baging
    Baging
    from Sweden
    Well....both sort of expensive and hard to find.... In our junkyards, there's only Volvo's Saab's BMW's and such :D
  4. henryj1951
    henryj1951
    from USA
    to bad yer so far away i'd run through em for ya for FREE...
    every once in awhile stock 882\'s.jpg i donate... like this set of 882's for a BROKE-n-POOR
    stock car guy( he helps around here) good kid...
    Baging likes this.
  5. BOBCRMAN
    BOBCRMAN
    from Holly
    Some of the older tooling was not as accurate as the later mounted carbide cutters. The staking is very ineffective, way too far from the seat. The seat needs a Serdi profiled cutter to remove that ridge and blend the seat into the bowl.
    Lots of flow restriction as they are now.
    Baging likes this.
  6. squirrel
    but, will they last another ten years? probably, eh?
    henryj1951 and sunbeam like this.
  7. henryj1951
    henryj1951
    from USA
    LQQKs like they will as pinched/staked as they are...
    cant FALL out....:cool:
  8. I've had staked seats fall out. Doesn't mean that those will.
    If I was going to check for cracks unless I had access to magna-flux cheap I would just die test them, then if they were suspect I would magana-flux.
    if they turn out to be **** we can find bare castings easy enough and I have been known to ship to the Norland.
    henryj1951 likes this.
  9. Baging
    Baging
    from Sweden
    Another reason to move over to you guys ;) :D
    That's good to know!!! :)
    While on the subject of valve location.....took some pictures of how they're sitting in the seats.
    Thoughts on this? :)
  10. GlassThamesDoug
    GlassThamesDoug
    Had a set updated with hardened seats. Never became loose or fell out. And I am sure there are plenty of O.S. over sized seats that work fine too for those that lack appropriate press fit. if they loosen you will grow lash....valve moving down away from rocker. Other then that..........RUN EM...
    Baging likes this.
  11. JC Sparks
    JC Sparks
    from Ohio
    "Yea. Could be the machinist in question stakes them all. They should not have to be staked. if the tolerances are correct the seat should stay by itself."
    I agree with the above statement 100%. If you can't hold tolerance, you should not be machining. I'd drop dead if I did a job and had to do that. JC
    Baging likes this.
  12. Baging
    Baging
    from Sweden
    [QUOTE="Gl***ThamesDoug, post: 11682679, member: 56892" if they loosen you will grow lash....valve moving down away from rocker. Other then that..........RUN EM...[/QUOTE]
    Ok. Will keep an eye on valve lash.....will run a mech cam, so i guess i just have to check lash a litte more frequent than normal ;) :)
  13. henryj1951
    henryj1951
    from USA
    I myself am NOT much of a BETTING man... but i'll wager
    that those WON'T ever FALL OUT let along wiggle LOOSE.
    they are pressed, staked -n- BENT in . (that's why i'd bet)
    annaway ya RUN em....
    heating heads -n- freezing seats -n- guides make INSTALLATION
    almost FALL IN..LOL...:cool:
  14. GlassThamesDoug
    GlassThamesDoug
    Set I had flowed with small 1.94 int and 1.50 exhaust. Seem to run OK on small engine. Get a chance to run them this Fall.
    Baging likes this.
