Technical Purple gun is on sale!!!!
Discussion in 'The Hokey Ass Message Board' started by willys36, Mar 4, 2022.
  1. You can drill the tip out.
    If you fuck It up your out 10 bucks
  2. CyaNide
    CyaNide
    from Texas
    How is it going to seal to the needle if you drill it out? It will leak and not work.
    CN
  3. The needle is tapered, you won’t drill bigger than the needle.
    My devilbis gun has 1.3 1.5 1.8 , 2.0 and 2.2 tips. Same needle just a bigger hole.
    I got an extra 10 bucks, I’ll prove it tomorrow
    Cosmo49, chryslerfan55 and VANDENPLAS like this.
  4. gimpyshotrods
    gimpyshotrods
    Yup, it's true. My Devillbis FLG gun has all of those tips, too.
    I have two purple guns that I have retired. I might cull the tips, and drill them out. Just need to see if I have those bits.
  5. gimpyshotrods
    gimpyshotrods
    I run lacquer thinner through all of mine to make sure that they are clean, before I use them. It has never disturbed the finish.
  6. lostone
    lostone
    from kansas
    Do you gents know what size drill bits for a 1.8 and 2.0 would be?
    Appreciate the info!
  7. They are called out in mm
    Squablow, chryslerfan55 and loudbang like this.
  8. lostone
    lostone
    from kansas
    Thanks 31vicky!
    I thought they were but figured easier to ask and make sure before drilling!!
  9. gimpyshotrods
    gimpyshotrods
    I rooted around in my Metric stuff and found a 2.0mm and a 2.3mm. Probably close enough.
    I will see if I can get a grip on them in the lathe, for accurate drilling.
  10. I have 2, used 1 to jamb my Ford and do the interior garnish and dash, shot acrylic lacquer through it. 1st thing, strip it down and clean it. The o-ring that goes under the bottlewas wonky, chucked that and got one from Ace Hardware.
  11. 26Troadster
    26Troadster
    we use the cheap guns at work to paint the drills we build and or rebuild. throw most of them away afterwards. now when i say drill, it's not a hand held. t4 ir truck drill is what we are rebuilding right now.
    VANDENPLAS likes this.
  12. ratrodrodder
    ratrodrodder
    from Boston
    @Bandit Billy, is this the one you used on your truck build?
    Bandit Billy likes this.
  13. Bandit Billy
    Bandit Billy
    Uh, no. But I could have bought 50 or so of them for what that Iwata cost. The digital regulator would have bought a couple more. My cupboards would look like @Moriarity 's :cool:
  14. It's been a while since I was in a HF. Podunk Yelm has apparently got beyond podunk as we got our very own HF store opened a week or so ago. The good is it's no longer a 60 mile + round trip to one (only 30 for me now), the bad is even with 'Grand Opening Specials' their prices have increased by quite a bit.
    chryslerfan55 and Bandit Billy like this.
  15. Bandit Billy
    Bandit Billy
    Yelm doesn't have a harbor. :cool:
    Steve Ray, A Boner and chryslerfan55 like this.
  16. lippy
    lippy
    from Ks
    Damn hotrodders, buy a $10 gun and spend $60 modifying it. :D
    210superair, Squablow and Moedog07 like this.
  17. Just divide the MM by 25.4 to covert to inches ( decimal )
  18. HF offers a larger needle and tip, just need to contact customer service. I got one for my primer gun. Performs great.
    Squablow likes this.
  19. Squablow
    Squablow
    Bought one this weekend to experiment with, based on this thread. For $10 it'll be fun to try.
    VANDENPLAS and A Boner like this.
  20. gimpyshotrods
    gimpyshotrods
    #25942 2.2MM tip
    #25943 1.9MM tip
  21. buick bill
    buick bill
    from yreka;ca
    with the price of paint nowadays i think its penny wise , and plain stupid ! and cutting / buffing is a lot like work . money down the drain !!!!1.......
  22. Jones St.
    Jones St.
    Did a huge pile of freshly sand blasted parts (A-arms/coils/leaf packs/core supports/crossmembers/frame/ect) w/one of these El Cheapo purple guns in both epoxy primer & paint. No problems at all. Go git!
    gimpyshotrods likes this.
  23. Jones St.
    Jones St.
    Cutting & buffing is work. Do it in sun & work on yer tan! And the shine is not to be surpassed. Was doing that to single stage DUPONT enamel 30 years ago.
    gimpyshotrods and seb fontana like this.
  24. Ebbsspeed
    Ebbsspeed
    They make a good flamethrower if you fill them with gasoline and hit the vapor with a striker.
  25. saltflats
    saltflats
    from Missouri
    I have never had any luck with HVLP paint guns, guess I didn't try hard enough. The Astro gravity feed gun works for me.
    If these guns are that cheap and you guys use them you should buy a bunch try them all and keep the one's that work the best.
  26. I use these often for primer, not so much for $1000 per gallon base or $400 clear. Personal choice by me.
  27. lostone
    lostone
    from kansas
    I use the cheap ones for primer only.
    Saves wear and tear on my good one.
    My step-dad was a bodyman/shop owner for many years and I watched him lay paint, both enamel and base/clear, with cheap guns and lay paint better than some of the body men who worked for me with a 500 dollar sata in the late 90's.
    He never paid over 25 bucks for one. I asked him about it one time and he told me take a guy that can't paint and put a 500 dollar gun in his hand and he still can't paint. Take a guy with experience and put a 25 dollar gun in his hand and watch what he can do. He summed it up and said experience is worth more than a high dollar tool.
    I agreed he was right.
  28. BamaMav
    BamaMav
    from Berry, AL
    I tried one once, didn’t like it. I learned to paint on a siphon gun with the cup below my hand, and still prefer that style. Cup on top just seems hard to keep level.
    My current gun is a Campbell Hausfield from Walmart. Costs a little more than the HF gun just like it, but I’ve had mine 10 years now. Painted several vehicles with it. May try a HF gun if I can find a siphon feed.
  29. I guess my problem is I never used a good gun. Got my start in the 50s with an old siphon gun my dad had as a time and materials handyman. Fooled around with a gun run by a vacuum cleaner, then when rattle cans came out I was in fat city for years. Bumped into HF in the mid 70s and their first generations of cheap guns were amazing step up from my previous experience. Was very poor so couldn't even think about a DeVilbis or Binks gun. The purple gun has always been a fantastic tool even after I got in the bucks in my career, I see no need to spend more. Save that for more tools!! Purple gives me a great job every time.
  30. Rand Man
    Rand Man
    They were 14.95 at my local store. Did I miss something. Was that an internet deal?
