Purple power
Discussion in 'The Hokey Ass Message Board' started by unkledaddy, Nov 22, 2009.
  1. unkledaddy
    unkledaddy
    My machinist uses Purple Power to clean aluminum heads.
    Has anybody had any experience using it to clean aluminum wheels?
  2. 52style
    52style
    it leaves them clean but looking dull i dont see any harm if you plan to polish them afterwards
  3. hotrod-Linkin
    hotrod-Linkin
    last time i checked,there is wheel cleaner that works without dulling the finish..
  4. MercDeuceMan
    MercDeuceMan
    from Indiana
    You can you a spray on wheel cleaner on polished aluminum as long as the P-H is a neutral balance. Look at the label on the bottle and it will state if it has a neutral P-H.
  5. fleetside66
    fleetside66
    Purple Power really works well for just about anything (esp. cleaning aluminum trim on houses), but no matter how many times you wash your hands, you still feel a residue. I've always been leery about using it to clean something that is going to be painted, because of the residue factor. Any opinions on this?
  6. onlychevrolets
    onlychevrolets
    HEY, make sure if you are going to clean wheels (or anything ) with Purple Power that ist is cool to the touch! It will ruin a polished wheel if it applied while the wheel is hot or warm.
  7. onlychevrolets
    onlychevrolets
    that's not a residue you feel. Purple Stuff is caustic..that is dissolved skin that feels slick. It reacts with the fatty tissue of your hands. We use a chemical thats a lot like purple stuff to clean BEER STONE from draught lines , it does that same thing to my hands.
  8. holeshot
    holeshot
    from Waxahachie
    hey UNKLEDADDY...i use it ti clean my cat. he doesn't have more power but he sure is purple...POP.
  9. Shifty Shifterton
    Shifty Shifterton
    Purple power will haze polished aluminum and isn't overly friendly to paint.
  10. GMC BUBBA
    GMC BUBBA
    Amen......... We use purple power ( and have for some time) on the reman distributors. Heres how we use it.....
    Clean the greasy , nasty distributor in a cuda wash at 185 dgrees and a mild soap..........dis***emble and gl*** bead all parts ( approx 80psi with the gl***)........blow dry and put back in the cuda for another high temp and pressure wash to remove all gl*** beads etc.
    Final wash for a few minutes in the purple power , makes the aluminum look orginal etc..........one more rinse in the cuda, blow dry ........looking good and orginal...............great stuff !!!!!!!!!!!!!! $ 25 or less for 5 gallons at advance auto........
  11. il Revrunde
    il Revrunde
    If you read on the back, theres a guide to dilute it. Its extremely caustic and yeah, it melts skin. I use the ratio for chrome to clean aluminum (15:1) and it works well. sometimes a bit closer to 10-12:1. Oddly though, Purple Power and Simple Green wil straight up MELT pearls for some reason. crazy
  12. unkledaddy
    unkledaddy
    Does anyone have a line on this stuff?
    BTW.........what a wealth of info available through the HAMB.
    Thanks you guys.
  13. unkledaddy
    unkledaddy
    Hot rods for purple cats...Daddy-O!!
  14. Hot Rods Ta Hell
    Hot Rods Ta Hell
    It has Sodium Hydroxide, which you'll also find in oven cleaners and commercial grade floor wax stripper. Wear gloves, as it will eat paint and skin. Castrol super clean is same type formula and works better IMHO.
    Model car builders dunk old "glue bomb" built ups in Purple Power or Castrol SC as it disolves paint but doesn't harm model car styrene palstic.
  15. oj
    oj
    Find another machinist..fast! That **** is citric acid. It will eat up aluminum and won't disolve grease, the grease and oil become a layer on top of the purple power (theres a bunch of other stuff with different names but is the same) in the parts washer, when you pull your parts out they'll get a coating of the **** you are trying to get off. The only good thing is that it is environmentally friendly. I don't know of any professional that would consider using it. I missed a couple linkage arms from injectors and left them in there for a week (in the small parts basket) and when i pulled it out to put some stuff in it there was hardly anything left of those arms - looked like something you'd find that had been in the ocean for a century or two. Nasty stuff that purple power.
  16. slepe67
    slepe67
    Do NOT use it on aluminum !!!! Read the fine print on the front. I sprayed some on my dirt bike cylinder, let it sit long enough to spray the rest of the bike. It pitted and corroded the casing, leaving that nasty, white corrosion look. Some guys in here said they used it without problems, I had HUGE issues with it on aluminum.
    I'm not calling anoyone out here, jsut stating MY personal experience. I would STRONGLY recommend using it on an incon****uous place first, THEN go from there.
    When in doubt, use Simple Green, diluted. THat stuff will clean ANYTHING.
    Just my $0.02.
