Technical Push Button 727: What All Do I Need To Make One Work?
Discussion in 'The Hokey Ass Message Board' started by Scotch Buzzard King, Nov 12, 2022.
  1. I want to install a push ****on 727 into a vehicle for which one was never designed. What are all the components I'd need to make one work?
    turboroadster likes this.
  2. fingers for starters ;)
    sorry I couldn't be more helpful but I am planning a trip, I intend to spend the next month riding my stationary bicycle around France :D
  3. I see your permanent residence. This couldn't be Lance Armstrong, could it? :D
    '34 Ratrod and Bob Lowry like this.
  4. Black_Sheep
    Black_Sheep
    Obviously you’ll need a push ****on shifter ***embly and shift cables. I believe the cables are being reproduced, but you’ll have to do a little imagineering to make them work in a non-stock application…
  5. Bob Lowry
    Bob Lowry
    Borntoloze really knows how to push your ****ons......
  6. Any chance anybody out there has a factory ***embly diagram for one of these shifters all put together? I can find the push ****on 727 fairly easily, but I'm lost as to how the cables actually connect from the shifter to the transmission.
  7. There is only one cable, and it works like any other trans shift. The push ****on unit just moves the cable in or out. Some have a "park" lever, some only have Neutral.
  8. bchctybob
    bchctybob
    Watching this one.
    I have a cable shift TF and cables that I’ve always kinda wanted to use but no push ****on mechanism. I’ve seen units with the ****ons in a row but the old Art Carr floor mount had the ****ons in a cluster. What car did that cluster mechanism come from?
  9. Moriarity
    Moriarity
    SUPER MODERATOR
  10. swifty
    swifty
    I have a Chrysler manual from the early 60's which I think has a drawing showing the push ****on ***embly and cable.Will have a look when I go out to the shed and report back.
    elgringo71 likes this.
  11. swifty
    swifty
    OK , checked and my manual covers full size Plymouth including Valiant for 62. There are pages of info on the push****on unit which needs two cables, a gearshift control cable and a parking lock cable. Lots of info and lots involved in setting up the unit. If you can't find someone local with a manual let me know and I'll copy and send it to you.
  12. caprockfabshop
    caprockfabshop
    Which version of the transmission do you have? The "first" 727 was 1962, but that's a one year only transmission. Is yours the 1963 to 1964? They stopped having push****ons in 1964, switching to column for 1965. I can definitely point you in the right direction once I know what we're working with. Post a pic if you can, that will significantly help in ID and then in selecting which push ****on setup would work best with them.
    ~Peter
    bchctybob likes this.
  13. greybeard360
    greybeard360
    In 65 the government required all shifters use a lever on the column or console... No more push ****ons. The 65 column shift cars and console shift still used the cable shift trans. It was a one year only deal. In 1966 the TF were lever operated instead of cable.
  14. I've got that shifter in my watch list, Moriarity. I dig that one the best at the moment.
    I have lever shifted 727s. I also have two 413s, one 440, and a 331 Chrysler. I also have a 55 T-Bird that I picked up from Lubbock a few years back. At one point, it was a custom before someone tore it apart to build a g***er that never panned out. Sat in someone's backyard for 50 years before I got it.
    I was hot and heavy on finishing the g***er which is why I purchased the 413s and the lever shifted 727s. The longer I've owned the car, however, the more the original custom parts have grown on me. I want to restore the car to what I think it would have looked like if it would have stayed a custom.
    The car came with a 64 1/2 Mustang Toploader. Right mods, and it can be a great transmission. It just doesn't fit my idea for the car now. I dig the Ford 3 speed Toploader. I especially like the one that Olds used in their 442 that were ordered from the factory with a 3 speed.
    I might start off the car with the "Dearborn" 3 speed just to keep the factory T-Bird shifter, but I can't shake the idea of the push ****on 727. If I could pick up a package deal with all the parts from one car, I think I'd be better off.
  15. caprockfabshop
    caprockfabshop
    In that case, it would seem that a 1963-64 Mopar would be the best donor. It would be hard to piece together with parts off eBay or from someone in a want ad; so I'd say your instincts are good to get everything from one donor. Cherry Ave in North Amarillo has a surprising amount of early 60's Mopars. I'd say start there!
    ~Peter
  16. There are two cables...one works reverse thru low, the other one works park only. Most all of the shifter box ***ys. are the same. The ****ons, in most cases are the difference. Some ****on set-ups before '62 had no park position. If you can find an Art Carr set-up you might want to pay what the person will be asking. I have a '64 Chrysler set-up in my '40, I like them because the ****ons are translucient and light up. '65 transmissions are the ones everyone wants because they are the only ones with a slip yoke. '63 Dodge car are the easiest ones to mount, most times you can mount them to the bottom of a dash. Gene.
  17. The one I had was from an Australian Chrysler, and had no Park cable, just 1, 2, N & R. I thought these would have come from the U.S. that way, but maybe they were made here. Park= neutral + parking brake.
    alphabet soup likes this.
  18. lippy
    lippy
    from Ks
    My 65 belvedere plymouth was a column shift but still had a cable to make it work, it also had park. so I don't think it's a big deal. 64's were push ****on with the lever for park. Your gonna have to get creative. Lippy
  19. lippy
    lippy
    from Ks
    Your gonna need the actuator(****on and lever ***y and trans and cables. Thats it. Lippy:)
    caprockfabshop likes this.
  20. winr
    winr
    from Texas
  21. I totally forgot about Art Carr. Remember seeing one for sale over a decade ago. Don't know why I didn't buy it.
    Went to the old Google search earlier when I found this:
    https://www.jalopyjournal.com/forum/threads/chrysler-products-push-****on-shifters-any-info.992622/
    And I saw this:
    And then I found this:
    http://www.aandatrans.com/Products/...Torqueflite-in-a-1962-65-Vehicle__AA3354.aspx
    All of this came from this one thread. This company makes a conversion cable set that connects from a Mopar push ****on shifter to a 1966 and up Torqueflite. Man oh man, does this fit my bill! Think I found a winner. :D
    egads and bchctybob like this.
  22. Yep...that's mine. Gene.
  23. A friend of mine has a 62 Imperial. He adjusted the cable(s), with the transmission pan off, so that he could see the "comb" inside the transmission.
  24. bchctybob
    bchctybob
    Looking at internet images, it looks like Art Carr used a mechanism from the early cars. The in-car photo from Pinterest was labeled ‘56 Chrysler. The ****on size and layout looks just like the Art Carr. No park provision either. In ‘56, Chrysler must have had a cast iron TorqueFlight with the brake drum on the tailshaft housing. The PowerFlight version only had four ****ons, IIRC. To make something similar to the Art Carr unit, one would need to find a ‘56 Chrysler TF push ****on unit and fab the rest.
    caprockfabshop and egads like this.
  25. Chrysler had two versions in 1956. The five ****on shifter was in the '56 Imperial while the four ****on shifter was in the '56 New Yorker. I found this out yesterday during my research. I found enough parts on eBay to build a four ****on shifter, but I'll be keeping an eye out for the five ****on.
    Evidently, you can use either with the conversion cables for a 727. The five ****on gives you access to first gear while the four ****on does not:
    http://www.forwardlook.net/forums/forums/thread-view.asp?tid=24089
  26. Besty34
    Besty34
    back in the nineties I ran a push ****on auto behind a 392 Hemi in my 34, the box was a 58 and the push ****ons were early sixties Dodge, I absolutely loved it. IMG_8658.JPG
  27. I really like this picture.
    Besty34 likes this.
  28. Ebbsspeed
    Ebbsspeed
    That would have been from a 2-speed PowerFlite, not the 3-speed TorqueFlite.
    bchctybob and caprockfabshop like this.
  29. BJR
    BJR
    Funny how no one wants to use the Edsel telatouch in their rod.:eek::p:D:p
    Dustin 257 and bchctybob like this.
  30. That's a good point.
