Hot Rods push rods
Discussion in 'The Hokey Ass Message Board' started by southern thunder, Feb 1, 2016.
  1. southern thunder
    southern thunder
    on a 350 chevrolet, how easy should the pushrods be able to turn with your thumb and finger while the valves are closed. the engine is around a 75- 76 if that makes a difference, and the cam is stock. should they turn freely, or have a little resistance?? thanks, Art
  2. squirrel
    Mostly they should turn freely.
  3. southern thunder
    southern thunder
    ok, thanks
  4. southern thunder
    southern thunder
    also, should there be any play in the rocker arm? should I be able to move the rocker arms around, like side ways at all?
  5. If the valve is closed back the rocker off to no play (or tighten it) then give it another 1/4 to 1/2 turn. When properly adjusted if you have fingers like Jim or me, you will be able to turn them but your hands may not be that strong. I know that my wife could turn mine when they were adjusted properly, she often checks my work and has since we were kids, but young engineer that she works with wasn't able to do so.
  6. southern thunder
    southern thunder
  7. southern thunder
    southern thunder
    thanks guys, there is alot of play in the rockers now. kinda like a solid lifter or even more. would this cause the backfiring, and hard to start, and no power on exceleration??
  8. Nailhead Jason
    Nailhead Jason
    If the valves are all out of wack adjustment wise it can do all of those things. Def a loss of power and would make a hell of a racket.
  9. Sporty45
    Sporty45
    It certainly isn't going to help. Get 'em adjusted properly and see if it helps
  10. southern thunder
    southern thunder
  11. Bandit Billy
    Bandit Billy
    As hyd lifters flatten and wear out it shows in the push rod slop as well. I always set them to where they spin in my fingers and then 1/4 turn to set them in the hyd lifter travel. Make a couple of p***es with the wrench. Obviously doesn't apply to solids.
    Backfiring and power issues sounds like timing issues, valves need to be properly adjusted to set timing though. Also make sure you aren't 180 out.
  12. squirrel
    I never worry about whether or not I can spin them. I set hydraulics so the rocker just does not have any slack, then usually half turn preload on the nut. On chevys, that is.
  13. King ford
    King ford
    from 08302
    The question to me would be why so much lash (so loose) ... If it is a high mileage engine the lobes may be starting to wear off of the cam, and t hat will cause backfire , power loss etc.
  14. Dennis D
    Dennis D
    Check the rocker ball and where it seats in the rocker for wear. D
