Projects Pushing King Fisher forward
Discussion in 'The Hokey Ass Message Board' started by Carl E. Hagan Jr., Sep 19, 2008.
  1. Just sharing. King Fisher Ice Co 1934 Chevy truck cab. 4inch chop after hammer & dolly'ing the entire back of the cab. Do'in the inner structure this weekend. Carl Hagan
  2. povertyflats
    povertyflats
    from Missouri
    Looks interesting Carl.
  3. Ramblur
    Ramblur
    COOL! Ice truck, get it haha. Here's some cubes for ya.
    Seriously though,progress is a great thing. Keep it going.
  4. Here's the rear corners, rear window & A pillars welded & cleaned. 20 ft of 1x1 left me around 80" short on the rear structure, so an addtn'l 20ft will be here tomorrow & the structure build begins. Carl Hagan
  5. BTTT for the night crowd, since I posted this at midnight last night. Carl Hagan
  6. sodas38
    sodas38
    Looking good, I'll keep an eye on this build.
  7. Here's the inner structure for the back half. Still need to get the square dies for the hossfeld, so I did the corners the hard way. I still need to clean it up with the angle grinder on the corners & then I'll put the panels on it. Oh...40ft of 1.1 in that alone. Had to pick up another two 20ft sticks to do the doors, cowl & floor support.
    Carl Hagan
  8. dirtbag13
    dirtbag13
    lookin good carl ! i will try to get u those pics of the cab i have
  9. bttt for the morning crowd. Carl Hagan
  10. ok....so I got the back of the cab done with just a few more tac welds to go. Doors pics to come shortly. Carl Hagan
  11. bttt for the morning guys, seems to be a little more action in the morning. Carl Hagan
  12. Shifty Shifterton
    Shifty Shifterton
    looks great, the clean backgrounds make it look easy!
  13. Any updates? I'm doing the same to my '34 right now...
    -mikethegreek
  14. James D
    James D
    What does this thing look like****embled? Have any before pictures?
  15. Here's the doors for now. Stripped, wood cut out, tops cut off & company sign re-lettered. (this is build is spare time between two jobs & two full time kids)
    I'll have the doors inner structure pics up shortly. Carl Hagan
  16. bttt for the morning guys. Carl Hagan
  17. Here's a door with the inner structure. Keep'n it simple for now. The 1inch tube is just behind the window channel, so I should be in the clear. Carl Hagan
  18. Here's the cowl structure. I'd like to add that the****embled structure in the cowl will not just pull up & out of the cowl. Because I wanted pics of just the structure only, I built this as a two piece structure which IS removable from the cowl and then spot welded into one weldment for these pics.
    I'll cut the spot welds, thus making it two pieces again and then****emble it back into the cowl and finish welded as one final weldment.
    Carl Hagan
  19. bttt for the morning guys. Carl Hagan
  20. Cowl structure spot welded into the cowl. I've still got plenty of work to do to it. The next pics should look like a truck cab. Nice. Carl Hagan
  21. skajaquada
    skajaquada
    from SLC Utard
    How are you going to be attatching the panels to the framework? I am going to be attempting the same thing in liu of the wood in my '29 soon.
  22. All the panels are to be welded solid to the structure. Cool. Carl Hagan
  23. Well, since most structure is completed, here's some teaser pics of the cab fitted together. Not welded or anything, but simply fitted together. Probly 1st time in 20yrs the cab has looked like a cab.
    Carl Hagan
  24. The day I got King Fisher. Carl Hagan
  25. Here are some pics of the cab spot welded together for fitment. Also, a couple shots of some floor structure. The door hinges took a bit of time to straighten out, they were all pretty kinked and twisted. Carl Hagan
  26. ironandsteele
    ironandsteele
    the first pics are what a hot rod would look like fresh out of the box from ikea.
  27. dirtbag13
    dirtbag13
    wow , thats lookin good , very nice work on making the steel to replace the wood , looks great and i know what a chore it must have been !
  28. This is as far as I'm taking the floor structure for now. I'm around 60" short of 1x1 to finish the cab, roof & all; into one solid piece. Hopefully I'll have the additional tubing Tues. and can start again. Carl Hagan
  29. bttt for the guys coming back from the Holiday.
    Carl Hagan
  30. Here is some work to the roof and adding some tube for the header / A pillars. Threw a weld pic in there for ya too. Carl Hagan
