Technical Putting a '38 Banjo steering wheel on a Model A.
Discussion in 'Traditional Hot Rods' started by Chris Haynes, Sep 21, 2022.
  1. I have to bore the taper in the wheel to the larger Model A size. Can anyone tell me the the correct size taper before I go hunting for the tool?
  2. rusty valley
    rusty valley
    I think it would be the right time to install a 32-34 steering box for the much improved 15 to 1 ratio, and then the banjo wheel would be a bolt on !
    Kiwi 4d likes this.
  3. panhead_pete
    panhead_pete
    @continentaljohn knows I think.
    continentaljohn likes this.
  4. Russ B
    Russ B
    It might be easier to splice the top of a 38 ford shaft onto your steering shaft. Steering shafts are not heavily stressed by the driver’s effort, especially if you have power steering.
  5. continentaljohn
    continentaljohn
    Chris it looks to be a easy task to open up the taper but with the key way in the taper it will follow the slot for the key and be oblong and incorrect. If your doing it on a mill or lathe it can be done.
    As @rusty valley suggested a later box such as a 1932-1934 would be a better box. You can interchange to steering box snout with your 1930-1931 and remove the 1932-34 snout splice . This way it’s a direct bolt on but with a later shaft . You may have to adjust your new length depending on the application. DFF4EED7-1EAB-4E86-9941-F4D8B4EB144F.jpeg
    rusty valley likes this.
  6. 62pan
    62pan
    I've done this. I could not find a correct reamer so after talking to a few machinists I found one that was close and then hand filed it to fit. My machinist friend joked a patient man with a file is better than a tool with a bad operator. Its fits fine and has been on there for years. I did have to refile the keyway. 20190501_080923.jpg
    trikejunkie and NoelC like this.
  7. NoelC
    NoelC
    So true. Nice wheel!
  8. I already have a new F 100 unit from Randy Gross.
