Technical Putting AC/Heat in 56 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by Clint Lovell, Sep 18, 2014.
  1. Clint Lovell
    Clint Lovell
    The defroster core is toast, blower motor does not come on, and am not sure about the underseat heater. Since I plan to put AC in anyway, I'm thinking that rather than the hangdown unit, I might go with the Old Air Products Hurricane system that contains everything. Problems I foresee is the brackets and pulleys to fit my Pontiac 316 V8. Has anyone done this switch and how did you handle the brackets/pulley issues? I have a single groove crank pulley, as well as a single groove water pump pulley. Right now the alternator is located on the top p***enger side.
  2. aaggie
    aaggie
    Call Vintage Air, if it can be done they will have everything you need. Alan Grove is the source for pulleys I use.
  3. Gman0046
    Gman0046
    aaggie has it right. I believe the new VA under dash hang on unit goes for right around $299. You can add that VA unit for less then repairing your old stuff.
    40StudeDude likes this.
  4. 40StudeDude
    40StudeDude
    Correct you are Gmann...the "new'' heater core for my '60 Chevy wagon cost me $238.00...and that was just the small heater radiator core that fit inside the heater ***embly...I about choked on my Coke when I went to pick it up. I think they saw me coming and said "Here, hold my beer and watch this...!!!"
    R-
  5. OLDSMAN
    OLDSMAN
    Vintage Air is a cl*** product, the only unit that I will use. They are good prople and have a good tech ***istance if needed
