Technical PVC Breather system
Discussion in 'Traditional Hot Rods' started by PeggySue, Dec 4, 2020.
  1. Blues4U
    Blues4U
    from So Cal
    That definitely p***es the "first glance test". It looks very natural in there. Good job.
  2. Tickety Boo
    Tickety Boo
    from Wisconsin
    Thanks
    The only vortec intake that looked like there was enough room to drill for tube was the (Summit brand) square bore, it was tight, didn't realize that manifold would over hang the front of the block so far. :oops:
  3. blue 49
    blue 49
    from Iowa
    I got mine shined up and installed. PCV behind the distributer.
    Gary
  4. IMG_1748.jpg IMG_2417.jpg Here's a pic of the engine I built for my 36 Chevy former g***er project. I wanted to keep it old school so I went with an Edelbrock C26 intake with the oil fill tube in the front. Corvette valve covers without breathers so I drilled & tapped the back of the intake just in front of the distributor for a screw in PCV valve. This goes into the lifter valley area. Needed a baffle to prevent the PCV from ****ing oil so I made one out of thin steel and screwed it on the underside. (not my picture but exactly how I did it).
    Just Gary likes this.
  5. buick bill
    buick bill
    from yreka;ca
    i put the fill tube in the performer in my 64 as well . painted it orange .no one seemed to notice . much better for adding oil to me !!
  6. birdman1
    birdman1
    Just wanted to commend all you guys installing pcv in your rods, jane fonda would be proud of you! LoL
  7. Yeah I know I should have gone 100% old school and just let it blow oil smoke out the breather all over my engine so it looks like ****.. Sorry man.
  8. 1971BB427
    1971BB427
    from Oregon
    I run a PCV valve on all my builds, just to keep the engine bay as free of oil as possible. It's one of the only environmental adds I do. But a PCV valve is good for the engine too, so not just about saving the world.
    This image may offend traditionalists, as it contains a PCV, and some OT valve covers on my '39 Chev. You're forewarned!
  9. dirty old man
    dirty old man
    I'm running a post '68 SBC block and an Edelbrock 2X4 bbl air gap manifold with no provision or room for an oil fill tube. The valve covers have 1 hole each, and in normal street use I have a PCV valve in one and a pleated cloth filter breather type cap in the other. If going to the drags where I may turn 6500 or more rpm, I pull the PCV valve, plug the hose and install a 2nd breather cap.
    To add oil I have a funnel that fits tight in the rubber grommet where either the PCV or the breather normally goes.
    alanp561 likes this.
  10. ClayMart
    ClayMart
    Also helps pull moisture and condensation out of the crankcase. ;)
  11. Bob Lowry
    Bob Lowry
    And it adds negative crankcase pressure which really helps to keep oil from pushing through gaskets and seals.
    ClayMart likes this.
  12. Norris McCarty
    Norris McCarty
    PCV systems work...period....lots of pluses with no negatives at all.
  13. Ranunculous
    Ranunculous
    I run a points-type Chevrolet factory distributor/cap with a Pertronix setup in it. No problems in the years I've had it.
    The roadster I'm working on will have the same setup. Easy to install and costs around $100.
