Q: 8ba block value?
Discussion in 'What's It Worth?' started by DreamerJ, Jan 31, 2024.
  1. DreamerJ
    DreamerJ
    I see a lot of different prices for 8ba blocks, what’s a fair price for a block with main caps that’s been tanked and magnafluxed by a machine shop without fatal cracks in the oil pan rail, valves, or cylinders? I have 1 to sell. Any advice? Thanks!
    seb fontana likes this.
  2. There must be a club with a web site and that would be a good place to look.
    Charlie Stephens
  3. DreamerJ
    DreamerJ
    thanks for moving this thread, i did not know this existed
  4. MAXWELL
    MAXWELL
    a few hundred..............
  5. banjorear
    banjorear
    What bore size is it and has it also been pressure tested. All flathead blocks must be pressure tested. Tanking and cleaning only tell you 80% of the story. Pressure testing confirms it's good.
    If it checks out, no heavy rust pits or wear in the bores and it's still under +.030", I'd say $500-$800 depending if it has 16 hardened valve seats, 8 in exhaust only or none.
