Q for Olds hydro guys
Discussion in 'The Hokey Ass Message Board' started by Shaggy, Feb 20, 2008.
  1. Shaggy
    Shaggy
    from Sultan, WA
    Is a 60's flat pan 4 spd hydro worth building for behind a hemi in a coupe? i saw one for sale local.
  2. DualQuad55
    DualQuad55
    from NH
    NO, the later hydros are not what you want. Ideally you want the cast iron dual range.I think they were something like 53-55 preferred. The later aluminum cased trannies were not anything you want to get involved with-obviously not referring to the th400-350 or glides.
  3. nor cal nic
    nor cal nic
    i like the '53 and earlier ones...
    nic
  4. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    Is the Hydro in my '58 Olds worth a ****? It's got a leaky front seal and I'm about to drop it and take it to the ****** shop to get it fixed, UNLESS it's not worth it. I like the way it performs...
  5. no, if it has park it's the later one. early ones reverse is park when shut off.
  6. d2_willys
    d2_willys
    from Kansas
    use a 54-56 Olds or Pontiac slant pan or 54-55 Cadillac flat pan dual range units. These have the 8 plate clutch paks and are the most durable of the dual range units. 52-53 units are also dual range but I believe do not have the bigger clutch paks. As far as single range (51 and back) units, only 1951 would be qualified as a usable unit, as the reverse ge****t was changed to hydraulic actuation for 1951, before that they were mechanically engaged (which meant you could grind it). As said in other replies, 56-64 hydramatics (other than 64 st400) were not very good trannies, especially slim jim rotos of 61-64 vintage.
