Quadrajet : help, before I kill again!
Discussion in 'The Hokey Ass Message Board' started by Plan_B, Sep 30, 2010.
  1. I suspect heat soak in my 454 from running too lean. The q jet it came with was for a 1970 350/350 combo. It now is on a 454/ 4spd a833. Current jets are 76 and 44 metering rods. The correct q jet for my set up would be 78 jets and 49 metering rods. Am I better off to switch these out or get a new carb? I just got a 3/4 wood carb spacer and a cool-tec heat sleave for the mech pump to carb hardline to help with the heat, but if I am to lean, these won't solve my issue. Any help would be appreciated! Thanks, Chris
  2. squirrel
    I'd suspect your heat soak problems are due to the gas they sell nowadays. Winter gas + warm weather = problems
    Lean could cause other problems. Or not.
  3. F&J
    F&J
    I'd like to know if the gas blends are causing problems on lots of older carb cars?
    I'm in the northeast and maybe we have more ethanol, maybe not, but I have had to rejet 2 old cars in the last month.
    The one I just did is a 48 plymouth woodie. The guy said it always seemed like plug missfire on hills. Just sitting still while holding it at 1800 to 2000, it really missed a lot. I just barely pulled the handchoke and it revved a lot higher and was smooth as silk. I drilled it out twice, in steps, and it runs mint.
    second car was a 40 year old bug standard trans. Bucking on medium loads like the Ply. The VW had a smaller main jet made for auto trans. The auto trans bugs had problems with epa tests back then. I put a standard-trans size jet in and it runs good. I almost think it could have used a bit bigger.
    If every car had a hand choke, it would be easy to tell while driving, if it was "way" too lean.
  4. I would look at the fuel well seaping a little gas at the butter flys a commond issue with Q jets jets seal with apoxy and done
