Quadrajet settings???
Discussion in 'The Hokey Ass Message Board' started by airbrushguy, Jul 22, 2007.
  1. airbrushguy
    airbrushguy
    from NJ
    I bought a "basket case" Quadrajet....all was there but all apart. Bought a rebuilding kit to put it together but it doesn't give measurements for lean idle, idle-air sgrews etc. It just says to pay attention to where they were when you took them out....I didn't take the mout though!
    It was originally a stock carb for an '86 Monte Carlo SS (305)
    Anybody have any ideas how I set it right without taking it apart a hundred times?
    Thanks
  2. Highgear
    Highgear
    lightly seat them (all the way in) and back them out 2 1/2 -3 turns ...
    "highgear"
  3. Bort62
    Bort62
    Careful, and '86 monte carlo should have been a feedback carb.
  4. airbrushguy
    airbrushguy
    from NJ
    What about that lean idle screw inside or that spring loaded one on top?
    Thanks
  5. Terry D
    Terry D
    from NY
    That carb is pretty complicated.Look at the exploded view real careful if you didn't take it apart.Also,if you're planning on putting this on a non computer motor,stop right there,that carb will run full rich all the time as the metering rods are electric instead of vacuum.Get a different carb if that's the case.If you're putting in back on the 86 Monte let me know and I'll give you the settings.
  6. airbrushguy
    airbrushguy
    from NJ
    Yes, I'm putting it on the Monte.
    Thank you.
  7. airbrushguy
    airbrushguy
    from NJ
  8. 53sled
    53sled
    from KCMO
    I have a bunch of q-jets, older 70s models with less ****. you want em?
  9. airbrushguy
    airbrushguy
    from NJ
    Very generous, thanks. Since I'm keeping the computer on it, the newer ones would only be the ones to work. If I decide to ditch the comp....I'll take you up on your offer.
    Thanks
  10. 53sled
    53sled
    from KCMO
    the "computer" is easily byp***ed. I had a 86 ss, swapped in an older hei and an older carb, (a**** other things) without a hiccup. Best was with a 377/th350, ran so much faster to 120, who needs overdrive?
  11. Frosty21
    Frosty21
    from KY
    Quadrajet has caused me nothing but problems on my G-Body El Camino.
