Technical Quads and PCV?
Discussion in 'Traditional Hot Rods' started by Roadhog56, Aug 23, 2023.
  1. Roadhog56
    Roadhog56
    Where do I hook up the PCV on my dual carter 9605's? Rear port on rear carb, front port on front carb, or to both carbs with a tee?
  2. If the intake has a vac port built in run it there. Otherwise the rear port on the rear carb (I am ***uming that the rear port is belowe the throttle blades and large enough for the air line)
    2OLD2FAST likes this.
  3. squirrel
    Wherever it fits the best.
  4. jimmy six
    jimmy six
    If running progressive linkage and you can possibly connect the hose or valve to the rear carb at the front of it that would be the best as it’s were most of the mixing with the blowby vapors and gasoline would occur.
    Next is a tossup between the rear of the rear carb or a fitting between the carbs which have used for 6 years..
    But like Jim says….where ever you can is sometimes the only option.
    RodStRace and Johnny Gee like this.
  5. wheeltramp brian
    wheeltramp brian
    I put mine on the rear of the front carb and I run my carbs without Progressive as that's the way I think they should be
    2OLD2FAST and jimmy six like this.
